Prop Plug in KiCAD? — Parallax Forums
Prop Plug in KiCAD?
I'm just attempting to have the four holes in a row for a set male header pins. Any suggestions?
  • evanhevanh Posts: 17,326
    edited 2025-11-25 22:45
    It's a 0.1" SIP connector. Same pin pitch as DIP IC packages. Looking it up ... In PCB Editor it's called PinHeader_1x04_P2.54mm_Vertical
    In Schematic just use a generic Conn_01x04_Pin and link it to the PinHeader footprint. Then save and reuse that template whenever you want the same in the future.
