Published Propeller 2 power consumption characteristics? — Parallax Forums
I can't find them. :(
I looked in the P2 Data Sheet under DC and AC characteristics.
I can take a clue from the large-wattage adapters used with the P2 eval boards, but I am guessing that power rating is meant to include a lot of peripherals.
Please and thank you.
  • RaymanRayman Posts: 15,894
    Guess it's complicated because it depends on the chip frequency, how many cogs are running, and what the I/O pins are doing...
    There is some info around here on that though...
    maybe searching with "site:forums.parallax.com power consumption versus frequency" or something like that will find it...
    One thing that uses all the cogs, runs way overclocked, and uses many I/O is the @Wuerfel_21 emulators.
    But, even these can run with just the regular USB 5V with 500mA limit power.
  • evanhevanh Posts: 16,988
    edited 2025-11-25 22:13
    With overclocking, it can be pushed to extremes for sure. I've managed to exceed 5 Watts on just the 1.8 Volt supply alone. The 2.5 Amp regulator was running overloaded even. And that didn't even include overvolting. But normally it probably won't be more than 1 Watt.
    PS: It wasn't a real world use. I did it purely as a maximum load case. The Prop2 overheated in a couple of seconds.
    PPS: Ada's game emulators, also overclocked, are more realistic maximums.
