Using the Linx TRM-433_LT — Parallax Forums
dennodenno Posts: 241
edited 2025-11-19 22:07 in BASIC Stamp
For a lot of years, now, I have used Linx transmitter/receivers with the Basic Stamp. It seems, now that the ones I have been using are obsolete. Kinda like me I guess. Anyways, now I am trying to use the above tx/rx wirelessly with two Stamps. I ;am trying to transmit a two digit number, to the receiver. I cannot determine the correct BAUD for the SERIN and SEROUT of the above Linx product. There is nothing in there DATA sheets other then MAX 10000 BPS.
So, the question is...has anyone used the above Linx with two different stamps? If so, what BAUD rate did you use for communication?
Thank you
