Latest and greatest OS for Propeller development? — Parallax Forums
VonSzarvasVonSzarvas Posts: 3,638
edited 2025-10-09 16:28 in General Discussion
Wondering what people are using these days in the non-Windows camp ?
I'm finding some computers (desk & lap) I use fairly often are not suitable for Win11, but appear to me impressively capable even without TPM 2.0. Generally they have i5 ~2.5GHz processors with minimum 8GB; mostly 16GB, all SSD.
I feel sure I've asked this before, but any up-to-date recommendations on a stable, trouble-free linux flavour that you're using with things like SpinTools IDE, VSC, Netbeans, Wine and Chrome ?
I'm quite comfortable with linux command line (running a bunch of mostly Debian servers as I do), but really want a lazy GUI experience for the work & home computers :) So I'm not spending more time on admin than getting on with the job!
I think Mint was one of the favourites last time I looked.
  • I'm newly running Mint (Cinnamon) with Spin Tools IDE. and had run Kubuntu for the previous 15 years, also worked fine.
  • evanhevanh Posts: 17,243
    edited 2025-10-09 23:11
    I'm using Kate editor on Kubuntu. Compile with plain Flexspin via Bash history. Loadp2 for download and terminal, Konsole's scroll-back is big feature here. Makes life liveable. :) printf() is both telemetry and debug. Occasionally check compatibility with Pnut on Wine, but its graphical terminal lacks scroll-back. :( Use Firefox on the forums.
  • KUbuntu here, too
  • Xubuntu, I have tried Kubuntu, it was to overloaded for my needs.
    Ray
    edited 2025-10-11 13:27
    I used to manually remove all the bloated PIM packages that were bundled, but in recent years the KDE installer system now gives an option to only install minimal packages and it's then up to the user to later individually install any extras you want.
    Another thing I always do is disable compositing. For some reason compositing, on X11, somehow drops rendered frames producing a display rate max of 30 FPS, often worse, no matter what the game rendering performance is. Officially, KDE 5.x doesn't support Wayland. KDE 6.x with Wayland will turn up with next upgrade so that'll require compositing but I expect it won't have the same frame-rate problem.
    PS: I have /home on its own partition. And two or three small (20 to 30 GB) boot partitions. Makes it easy to do fresh OS installs at will while keeping my prefs intact. Just have to tell the Grub setup where it is, which is usually an optional set of menus in the install process.
  • I was thinking of moving all my Win 10 PCs to Linux, but I will try MS's 1 year paid extension first.
    Been more than two years, now and not a single problem...Rock solid, fast and zero annoyances
  • I'm all for using Linux. it is my preferred OS
    But, it is possible to use Rufus (You can get it from the Microsoft store..) to create an iso that will install win 11on almost any computer without the secure hardware. If you disable some things (Smile fixer) it will run in a somewhat non-sucky way even on some older machines (Old engineering laptops I rescued from the dumpster at work) I even do 3d scanning with one of them.
    Rufus can also remove that crummy PIN and Microsoft account junk.
  • R BaggettR Baggett Posts: 272
    edited 2025-10-17 10:16
    Why did Smile fixer turn into smile fixer?
    Hmmm.. shows up as ?
    in edit.. must be forum filter..
    edited 2025-10-16 13:48
    Removed
    "Smile" is the forum's swear word filter.
  • Ok, Nice feature.
    The software I was describing helps to remove many of the resource gobblers that come enabled in win11 by default. Can I say it is an anagram of 'carp'?
  • Surprise! I have a free year of Win 10 updates with my MicroSoft account.
  • I have only just started with Propeller 2 development, so I don't know what it is like on Windows. But I have been using Fedora 42 for 100% of my P2 programming and it seems to all just work fine.
    Caveat might be that I haven't used windows since windows 98 ish, so I might have had more trouble on Windows than on Linux. But if you're asking whether you CAN use Linux for P2 development. As a newbie to P2 development I'd say "yes!"
    Good luck! Let me know if I can help.
