Are Nema23 stepper motors defective? — Parallax Forums
Hello everyone,
I'm currently building a gantry milling machine. For this, I purchased three nema 34 stepper motors and a TB6560-based oyostepper controller.
Now that I've connected all three motors, I've noticed some strange behavior with one of them:
When starting slowly, it jumps back and forth before running normally. However, its direction of rotation is erratic.
The other two motors run perfectly fine. I then swapped the motors and controllers, but the problematic motor still behaved the same way.
Thus, I can rule out a control error. Measuring the resistance of the connected windings on all motors showed approximately 1.6 ohms.
So, the windings are clearly fine.
My only explanation for this is that the windings of the allegedly faulty motor are wired incorrectly. As I mentioned, these motors are brand new.
Has anyone experienced anything similar?
Thanks in advance
  • Christof Eb.Christof Eb. Posts: 1,584
    edited 2025-08-05 11:04
    While I have not yet seen this type of behaviour, I often work with step motors. In my opinion this motor is faulty and I would contact the supplier to get another one.
    Good luck!
  • i would check out your control setup and check the wiring sequence. Make sure your clock signal has enough current to drive the clock line.
  • Is this a 4-wire or a 8-wire motor? With 4 wires you can't connect them wrong. If both windings show 1.6 Ohm it should work.
    However, 8-wire motors can be connected in many different ways. If one of the windings for parallel or serial connecteion is reversed it will still show the same resistance but the inductance will be ineffective if the polarity is wrong.
    You can check this by turning the motor manually while shorting one winding. You should feel a strong detent torque. If the motor still turns freely there is something wrong with the connections.
