[SOLVED][FlexSpin] Confusion about pointers to structures or compiler bug? — Parallax Forums
avsa242avsa242 Posts: 491
edited 2025-05-25 17:00 in PASM2/Spin2 (P2)
Hey @ersmith
Can you tell me if I'm misusing pointers to structures or if this might be a bug?
Consider this top-level object:
{Spin2_v51}
con
    struct mystruct(...
        word m1, ...
        word m2, ...
        word m3)
obj
    ch:    "child"
pub main() | mystruct realstruct
    ch.set_struct(realstruct)
and its child object
{Spin2_v51}
con
    struct mystruct(...
        word m1, ...
        word m2, ...
        word m3)
var
    ^mystruct   pstruct
pub set_struct(p_hdr)
    [pstruct] := p_hdr
fails to build with error: Bad number of parameters in call to set_struct: expected 1 found 2
This originated from a UDP header parser/writer I'm working on. My intent is to have the actual instance of the UDP header structure defined in the calling object, and just a pointer to it in the UDP object. The UDP object would be able to indirectly read/modify the instance.
I have similar objects for other network layers (e.g., eth-ii, IPv4) that use the same syntax and they build fine and seem to work - that's why I wasn't sure if I hit a bug.
Thanks!
  • @avsa242 I think you forgot an @ in the call to ch.set_struct. and also didn't declare the parameter to set_struct to explicitly be a structure pointer. You have to do at least one or the other in order for the compiler to figure out that you want to pass a structure pointer rather than the whole structure.
  • Great, I was hoping that's all it was. At first, changing only that didn't help (still had garbage data and/or crashes). Despite seeming to work, the earlier protocol dissectors (eth-ii, ipv4) were written the same way they are in my first post. They both built and worked fine, but obviously it was just a case of I got lucky and it "happened to work." :smile: After rewriting them the same way, all three now work correctly.
    For (hopefully) clarity, the change I made equates to this change to the first post:
    ch.set_struct(@realstruct)
    I found if I made that change and defined the param in set_struct as a pointer to structure, everything still worked, but a warning about incompatible pointer types was generated during build.
  • @avsa242 The warning about incompatible pointer types may safely be ignored, and I've fixed it in github. The type checker was being a bit too zealous for Spin2. which has very relaxed "types". The root cause is that we automatically convert structs being passed to ^structs to pointers, and also convert @struct to a pointer, with the result that the conversion was happening twice and we were getting a pointer to a pointer to the struct.
