Hardware oddity: HUBEXEC from memory below $400 — Parallax Forums
CON
_CLKFREQ = 100_000_000
DAT
              org
              loc pa,#$+1 ' < PA = 1 in cogexec, PA = 4 in hubexec
              mov thedbg,#0 ' to prove the point, delete cog copy
              cmp pa,#1 wz
        if_z  skip #%10
        if_z  jmp #\$FFFFC ' go for the wraparound!
thedbg        debug("hubexec from low memory!!! ",udec(pa))
QED.
  • roglohrogloh Posts: 6,414
    edited 2025-05-20 03:44
    Sneaky. So when wrapping from $FFFFC to $0 the P2 doesn't realize it should be switching back into COG mode and allows you to execute from 0-$400 as HUBEXEC? Or is this a toolchain artefact of some sort? What is actually sitting in the binary image loaded at HUB address 0? Is this using PNut or Flexspin?
  • evanhevanh Posts: 17,316
    edited 2025-05-20 08:08
    It is slightly surprising that Chip did it like that. So it's a select bit set by branch instructions rather than a live select based on the instruction fetch address from the PC register.
  • TonyB_TonyB_ Posts: 2,279
    edited 2025-05-20 10:11
    Interesting. Does it make any difference if instruction at $FFFFC is not skipped? Once in cog RAM exec starting at $0 any branch to below $400 switches to cog or LUT RAM exec, presumably.
    EDIT:
    Does next instruction after $3FF in LUT RAM switch to hub RAM exec at $400*4? I've forgotten.
  • The skip is just a courtesy, since $FFFFC is debug-locked and might contain something disturbing. I could have of course used the FIFO glitch to write a NOP there, but that'd be distracting from the actual point.
    edited 2025-05-20 14:15
    @TonyB_ said:
    EDIT:
    I did test that once-upon-a-time but I don't remember either. It's quite likely it wraps back to cogRAM address 0.
