No Propeller 1 found on any serial port — Parallax Forums
cavelambcavelamb Posts: 724
edited 2025-03-29 17:46 in PASM/Spin (P1)
Just started happening recently.
First time access a P1 is okay.
Can detect hardware or load ram just fine.
Once.
But second time - No propeller found.
Unplug and reconnect -
It's Baa-ack...
What's that about?
  • Is there a program running on your P1 that is interfering with the download process. If you have a reset button on your P1 board, press it and release just before as you click to download.
  • Yes, there is a program running from ROM.
    But pressing the reset button just before clicking on the menu item
    didn't do anything different. (Quickstart)
    Still have to cycle the USB cable
  • cavelambcavelamb Posts: 724
    edited 2025-03-29 21:03
    Checking preferences -
    Propeller reset signal is supposed o be DTR & RTS?
    It is working correctly that way at least.
  • Standard Propeller Plug and board designs use DTR as the reset signal for the Propeller. I found the QuickStart schematic on my computer and verified this.
  • Thanks, Jon.
    When I checked it (finally) Prop Tool was set DTR only.
    Set for DTR/RTS made Prop Tool work.
    I just now changed the USB cable and Reset back to DTR.
    All good.
    Bad Cable?
  • RaymanRayman Posts: 16,391
    I’ve had bad cables in the distant past where things like this would happen.
    Mostly the retractable kind.
    These days get bad iPhone cables all the time.
    Think usb-c is way to go. Think need p1 board with that. Have not seen that fail yet. But also new, so who knows …
  • RossHRossH Posts: 5,754
    Yes, I have also had problems with the retractable cables. I stopped using them for anything a while ago.
    Another problem is that there are two common types of USB mini and micro cables - charging cables and data cables. Charging cables are mainly intended for charging devices and may not have all the pins wired up - some will also work as data cables and some won't. I have not seen this problem with USB C cables. USB C is also more robust, and you can't plug them in the wrong way - the number of USB ports on expensive devices I have seen ruined by having the cables forced in the wrong way would make you weep.
    Really, no-one should be manufacturing new products with anything except USB C.
    Don't worry, charge-only USB C cables exist just as well. Gotta save 5 cents on those 2 strands of copper.
