Why should I do such an assignment?
ErNa
pub testmumpf (mumpf) mumpf := mumpf
this procedure can be compiled. But what actually happens?
A second question: how to create a newline when displaying code ? Thanks, solved
[code]
mumpf := mumpf
[/CODE]
Triple backtick block, like this (escaped for demonstration)
Code here
as I do not work with SPIN2, I cannot help you much with this question other than that a look into the .lst file is sometimes very interesting.
I would assume, that nothing happens and if the optimizer is good, it will throw out all of it.
Now off for a look at Hochrechnungen....
Best regards Christof
I'm using Propeller tool, just to KISS. Expect to switch to another IDE only after having a first simple application running, I move from P1 to P2.
What created the .list file ?
Anyway: I started to write a statement like ab= a, using copy and paste resulting in a = a . Then I left the scene without adding the b, later returned, compiled and wondered, why no error was thrown, as it makes no sense to change the value of an input.
Or is this an intended behavior for quick stimulation of a function to test?
With the usual Spin interpreter:
There is no error because it is legal syntax. The fact it is achieving nothing functional is not the compiler's concern.
Christof's reference to a .lst file was probably from the Flexspin compiler. It provides a textural listing of what goes into the binary executable. Here's an example compile-to-native snippet:
01ec4 | _mountsd_0143 01ec4 02 4A 06 F6 | mov COUNT_, #2 01ec8 28 01 A0 FD | call #pushregs_ 01ecc 84 00 00 FF 01ed0 5F B8 06 F6 | mov arg01, ##@LR__2444 01ed4 | ' return _umount((char *)user_name); 01ed4 AC C2 B0 FD | call #__system___umount 01ed8 20 92 06 F1 | add ptr___system__dat__, #32 01edc 49 01 68 FC | wrlong #0, ptr___system__dat__ 01ee0 20 92 86 F1 | sub ptr___system__dat__, #32 01ee4 4A C5 02 F6 | mov local01, ptr__dat__ 01ee8 08 C4 06 F1 | add local01, #8 01eec 15 B8 06 F6 | mov arg01, #21 01ef0 14 BA 06 F6 | mov arg02, #20 01ef4 10 BC 06 F6 | mov arg03, #16 01ef8 17 BE 06 F6 | mov arg04, #23 01efc 16 C0 06 F6 | mov arg05, #22 01f00 48 C7 02 F6 | mov local02, objptr 01f04 62 91 02 F6 | mov objptr, local01 01f08 A8 3A B0 FD | call #_sdsd_cc__sdsd_open 01f0c 63 91 02 F6 | mov objptr, local02 01f10 4F C7 0A F6 | mov local02, result1 wz 01f14 98 00 90 5D | if_ne jmp #LR__0210 ...And that was generated from:
static FILE * mountsd( void ) { FILE *handle; int rc, clkdiv; umount("/sd"); _seterror(0); handle = DRV._sdsd_open(CLK_RL, CMD_RL, DAT0_RL, PWR_RL, LED_RL); if( !handle ) { ...evanh, thanks for showing this. I ran into a problem moving SW to the P2, surprise: I had no problems using @@ in Spin, but something went wrong when I did the same in ASM. So I had to refresh (or gain) understanding how pointer addresses actually work. In the end I realized, I missed to instantiate a variable, and now it looks, I'm fine in this respect.
Oh, yes, I meant this. Sorry for being unclear.
