What is the proper usage of REBOOT in P2?
Larry Martin
in Propeller 2
Hi folks. It looks like REBOOT doesn't work in P2 with Pnut42.
Here's my code:PUB HPS_SendMem(p_hexval) | qlong, qbyte, qbit, ix, ch, rdr, dataIxCASE p_hexval...82: '0x52, "R"orgREBOOTendFourrdrs.Str(K4RdrHost, string("Reboot FAILED."))
REBOOT failed as a SPIN command:
error:Expected an instruction or variable
So I framed it as inline assembly. When I run the command I get the "FAIL" message and my firmware version is still the one running in RAM, not the one in Flash (which would be 27Dec):
Q52!
Reboot FAILED.
V00!
ThreeReaderEncodeP2_28Dec2024 (c) 2024 GlueLogix Inc. All Rights reserved.
I looked in the docs. REBOOT is either not mentioned, or described loosely like it just works.
What am I missing?
REBOOT should be a Spin statement. Though if it errs, that probably means it was forgotten at some point...
The correct way to reboot in PASM is
hubset ##$10000000, so that should work in inline asm.You can do it in straight Spin2 as well.
Thank you, that worked.
