P2 Edge Module Breadboard specifications — Parallax Forums
I looked for the electrical specifications for the Breadboard Module, but all I could find was a statement saying that the max. mA per group of 8 pins is 300mA.
But what is it per pin if I only use 1 pin out of the group of 8 pins? 300/8 mA?
I'm looking to program a basic LED setup on a breadboard with a 20mA current draw, and I want to ensure the device remains intact.
I was also wondering how to get + and - onto the 4 Breadboard blocks, already marked with + and -. Do I need to "jumper" them?
Preben
  • evanhevanh Posts: 17,317
    edited 2024-12-03 21:14
    Usually 5 mA is good for most indicator LEDs. You don't want to be cooking them either.
    The Prop2 datasheet says absolute max 30 mA per pin. https://www.parallax.com/propeller-2/documentation/
    PS: The default FAST pin drive strength is around 20 ohms. So, at 30 mA, that is 0.6 V and 18 mW of loss.
  • RaymanRayman Posts: 16,460
    edited 2024-12-03 22:45
    Think there's also a 120 mA max for every group of 4 pins.
    But, the edge has 1 LDO regulator for every 8 pins, with a max of 500 mA. That's probably the source of the 300 mA limit...
    That plus 120 times 2 is 240 mA...
    So, there's limits per pin, per group of four, and per group of however many are connected to the regulator...
    Still, actual limit for 8 pins has to be 240 mA, by the datasheet.
    Doesn't matter if sourcing or sinking, it's 30 mA per pin...
  • Preben you'll be absolutely fine at up to 30mA, we've done testing beyond that and never had a failure yet
    I've been looking into this and it seems the Vss connection to the 4 pin group is much stronger (lower resistance) than the 3v3 connection, which perhaps comes via a longer gold wire bond. Thats what I'm thinking, it would be good to confirm with Chip.
  • I will soon start playing around and will have more questions for you.
    I do try searching and may find answers in previous posts before asking questions.
    Thanks all!
    Preben
