Preprocessor? — Parallax Forums
Preprocessor?
I'm working my way through thousands of messages in various threads regarding Spin2 in search of whether a preprocessor was ever added to Spin2. I have found several requests for such an addition but have come to a dead end so far. Apparently I'm striking out - did I not peer deep enough into the evolution of Spin2?
#include, #def, #ifdef, etc., would be very nice. By the way Macca has done an exemplary job with Spin Tools. Thank you Marco!
-Mike R...
  • evanhevanh Posts: 17,142
    Flexspin supports them.
    Chip was talking about it a while back but I suspect it got buried under his ever growing list of todos.
  • PNut-TS also supports preprocessing, but when I last tested it, it was a bit bugged. Should be fixed by now.
  • maccamacca Posts: 1,015
    Thank you!
    Spin Tools IDE supports C-like preprocessor statements, for both Spin1 and Spin2.
  • Evan, Ada, Marco - thank you much. This has me headed in a far more organized direction!
    -Mike R...
  • Spin Tools IDE supports C-like preprocessor statements, for both Spin1 and Spin2.
    Where can I find documentation on the specifics, Marco? While I tend to keep my code backward-compatible with PNut, it might be time to move past that given PNut is not keeping up with customer needs.
    As usual there isn't a documentation (big weak point, I know), however if you have some C experience you can use nearly the same syntax:
    #if !defined(KB_USB) and !defined(KB_PS2)
    #define KB_USB
    #endif
    #ifdef KB_USB
        hc     : "usb-fs-host"
    #elseifdef KB_PS2
        hc     : "ps2-host"
    #endif
    These are examples from my P1 vga terminal firmware.
    There are some limitations, like can't cross CON/VAR/PRI/PUB/DAT sections.
