Universal Motor Driver DC Brush Motor demo code — Parallax Forums
The online guide shows this drive can be used with DC Brushed motors yet doesn't point to any demo software for a start. Current demo and advanced code is for BLDC motors. Also, there is a difference in REV A & B. however I don't know if it matters for code. I have 2 Power chair motors I would like to use with it.
They are 24 VDC and preliminary amps testing went from 3 no load and 6 with hand friction on shaft. I am also wondering if this can be controlled by another MCU like BS2 or P1. I am looking at the hardware that is on the BOM for both REV thinking I need some PWM Robot code to try. Any questions and suggestions would be nice.
  • Guy over on the LinuxCNC forum uses these These
    on his CNC mill retrofit and he's really happy with them.
    Was sure that I ordered some but apparently not.
    Craig
  • My apologies for not being clearer,again. I was referring to Parallax product SKU 64010. https://www.parallax.com/product/universal-motor-driver-p2-add-on-board/ I do have a couple of those exact drives I used on an Arduino project. They sure came down in price.
    Now, to myself, "where would that software be"?
    perhaps it would be a good idea to use a very small motor first to do some experiments. Use the rated voltage for that motor as supply voltage. Switch the low side of the H-bridge on permanently. Then switch on and off the high side. After that works use a PWM signal to the high side.
    Good luck!
  • @Mickster said:
    Guy over on the LinuxCNC forum uses these !
    I'm not familiar with LinuxCNC or the guy. What kind of CNC mill is it? A mounted Dremel wood router? Knee mill? Can you show a link for me?
  • VonSzarvasVonSzarvas Posts: 3,623
    edited 2025-04-08 05:50
    @McGyver There is a demo with code for brushed motors in the P2 quickbyte series. Based on converting an Arlo bot to use that Universal controller.
    Edit: Found the link:
    https://www.parallax.com/arlo-conversion-to-p2-with-the-universal-motor-controller/
  • MicksterMickster Posts: 2,902
    edited 2025-04-08 06:53
    I don't remember the thread but This one has a video showing same
    Might be worth searching BTS7960 on YouTube.
    Edit: Just had a search on YouTube and found lots of examples.
