Determine if a pullup is on a PIN or if it is floating — Parallax Forums
ke4pjwke4pjw Posts: 1,312
edited 2024-10-29 20:56 in PASM2/Spin2 (P2)
I did something like this on the P1, per @"Phil Pilgrim (PhiPi)" , to detect if a pin had a pullup on it, or if it was floating. It works incredibly reliably.
Can this also be done on the P2? I don't know if PINF is a FLTL or FLTH.
PINL(55)
PINF(55)
if PINR(55) == 1
    ' Pin has a pullup
  • If you're looking for an external pull-up, you may want to use pinclear() so that any internal connections are removed.
  • So something like this?
    PINL(55)
    PINCLEAR(55)
    if PINR(55) == 1
        ' Pin has a pullup
    I am going to give this a swing tonight. Thanks!
  • JonnyMacJonnyMac Posts: 9,795
    edited 2024-10-29 23:02
    I tend to be cautious, so I might do this:
     pub has_xpullup(pin)
      pinclear(pin)
      pinlow(pin)
      pinfloat(pin)
      return pinread(pin) == 1
  • evanhevanh Posts: 17,173
    edited 2024-10-29 23:30
    An extra cautiousness would be to have a known delay between the float and the pin read. Then a faster execution won't inadvertently sample before the pull-up crosses the threshold.
      pinclear(pin)
      pinlow(pin)
      pinfloat(pin)
      waitus(1)
      return pinr(pin)
  • I had to use float low. I suspect pinfloat is the same at FLTH.
    Thanks guys!
    PUB HardwareVer() : r
      PINCLEAR(ENC_P)
      org
        DRVH #ENC_P
        FLTL #ENC_P
        DRVL #ENC_P
        FLTL #ENC_P
      end
      waitus(1)
      debug(udec_(PINREAD(ENC_P)))
      if PINREAD(ENC_P) == 1
              ' Pin has a pullup
        debug("Version 2 hardware")
        r := 2
      else
        debug("Version 1 hardware")
        r := 1
      return r
    Why is that DRVH there? Did it help in some way?
  • AribaAriba Posts: 2,697
    Another possibility on the P2 is to enable a weak internal pulldown resistor and then read the input. Any external pullup lower then the internal pulldown will pull the input high. This doesn't depend on timing.
      wrpin(PIN, P_LOW_150K)      'enable internal pulldown of 150k
      pinl(PIN)
      if pinr(PIN)                'an external pullup will pull it high
         'there is a pullup
      pinclear(PIN)               'disable internal pulldown
    Andy
    edited 2024-10-30 13:24
    Hehe, one step further is use the compDAC pin mode to measure a floating ADC - https://forums.parallax.com/discussion/174441/measuring-floating-pin-voltage-adc-from-just-the-built-in-comparator
      pinl(PIN)
      if sar_reading(PIN) > 5    'an external pullup will pull it high
         'there is a pullup
    This will work well with even very high pull-up resistances.
  • Thanks guys, all around! What I have works but I will keep these in my back pocket. I am using a 100K pullup.
    Oops, the pin mode above doesn't combine with the SAR routine. CompDAC pin mode can do a 1k5 pull-down though. So still a possible approach there,
    You know, I'm gonna add this to the SD driver code. The confusion that occurs if the pull-ups aren't in place are worth the extra code to check for them. Good reminder Terry. Thanks.
