Spin code issue - Repeat loop only repeats once
DiverBob
Ran into a problem where a repeat loop (repeat index from 1 to stepIncrement) should have looped 20 times but it stops after completing the first loop. Its acting like it is hanging up as no debug statements past the initial loop are displayed. Hoping someone else can see what is going on here. The second repeat loop for elapsed time is working correctly. I am using the current version of Spin Tools and no errors are indicated prior to running code.
debug("-------- start runTest5 ----------")
'repeat loop to get each x,y,z position along stride path
'elapsedtix is timer output counting 10msec segments
time := elapsedtix
'initialize step movement
legGaitX[n] := legXActual[n]
legGaitY[n] := legYActual[n]
legGaitZ[n] := legZActual[n]
debug("Leg ", sdec_(n), sdec(bodystride), sdec(legangle[n]), sdec(resolution), sdec(stepincrement))
debug("Step distance: ", sdec(legXIncrement[n]), sdec(legYIncrement[n]), sdec(legZIncrement[n]))
debug("Leg start position: ", sdec_(n), sdec(legGaitX[n]), sdec(legGaitY[n]), sdec(legGaitZ[n]))
debug(" ")
debug("---------- Start timed movement Step: ", sdec_(index), " ----------")
'use msec delay to slow down movement and not use motor stop flags
'add distance to move in x,y,z
legGaitX[n] := legGaitX[n] + legXIncrement[n]
legGaitY[n] := legGaitY[n] + legYIncrement[n]
legGaitZ[n] := legGaitZ[n] + legZIncrement[n]
debug("Next Position Leg ", sdec_(n), sdec(legGaitX[n]), sdec(legGaitY[n]), sdec(legGaitZ[n]))
'move leg to new coordinates using IK for motor angles
fangle, tangle, cangle := moveToCoordinate(n, legGaitX[n],legGaitY[n],legGaitZ[n])
'extra time to take up backlash on first iteration of loop
if index == 1
backlash := 50
else
backlash := msecdelay
debug("Move cycle timer interval: ", sdec_(backlash))
'timed delay for smoother motor operations
etime := elapsedtix - time
repeat while elapsedtix - time < backlash
time := elapsedtix
debug("Code timer (msec): ", sdec_(etime))
debug("------- End Intermediate Step -------")
debug(" ")
debug("------- Complete Movement Steps -------")
Debug code for above code
Cog0 -------- start runTest5 ---------- Cog0 Leg 1, bodystride = 200, legangle[n] = 450, resolution = 10, stepincrement = 20 Cog0 Step distance: legXIncrement[n] = 7, legYIncrement[n] = 7, legZIncrement[n] = 0 Cog0 Leg start position: 1, legGaitX[n] = 21, legGaitY[n] = 214, legGaitZ[n] = 634 Cog0 Cog0 ---------- Start timed movement Step: 1 ---------- Cog0 Next Position Leg 1, legGaitX[n] = 28, legGaitY[n] = 221, legGaitZ[n] = 634 Cog0 ---------- moveToCoordinate ---------- Cog0 Leg 1 New angle positions: Femur: 899 Tibia: 4 Coxa: 827 Cog0 Transmited command: $,1,899,4,827,1 Cog0 Move cycle timer interval: 50 Cog0 Code timer (msec): 5 Cog0 ------- End Intermediate Step ------- Cog0
Is stepIncrement a global that could be modified outside of this code?
Tapping the usual sign: You should isolate the problematic code so you can post a full compile-able example. (Though many a time you will find your problem while doing that)
My money is on the
moveToCoordinatecall corrupting RAM somewhere.stepIncrement global variable is set in an earlier routine and not modified during this routine. this is the only place I’m using the local variable ‘index’.
That why I added debug code at the start of the loop, the end of the loop and a debug statement should be shown when the loop completes. What gets me is that the debug statement at the end of the loop executes as expected but index doesn’t go to the next value of 2. The loop isn’t being aborted as the debug statement after the loop isn’t running. It looks like the repeat command is getting corrupted and so the program just hangs up at this point.
I will look at moveToCoordinate() a bit closer and make sure there isn’t anything in there that could impact the loop.
Update: I copied an older version of the moveToCoordinate() routine into the code and the repeat loop started to work again. Then I changed one line of code at a time and tested each change to see which code line would cause it to stop working. By the time I was done the replacement code matched the code that doesn't work but the repeat loop is still working.
So I'm still not sure why caused the repeat loop to stop but at least I can continue working
Gremlins...it was gremlins.
On a more serious note, I would be tempted to do a file compare between the two routines and see if there is a difference that I missed.
