confusion when debugging assembler [solved]
ManAtWork
I have to admit that I don't fully understand how the debug interrupt and the BRK instruction work internally. What I do know or at least I thought I knew is that I can place debug() statements to my assembler code and if it's not too time critical I should be able to see what happens to some degree.debug ("test message")
tells me that control has reached this statement when the message appears in the terminal.debug (sdec (var1, var2))
prints out the values of the variables (cog registers). There may be some limitations in which case this doesn't work, for example, care should be taken not to place a debug between "linked" instructions like SETQ or ALTx and the following instruction. I also expect trouble when using debug() inside REP or SKIP sequences.
However, when using debug() in a linearly executed sequence of instructions without any jumps, branches or loops I would expect them to print the debug messages also in a linear order, one by one.
So I was very surprised that sometimes debug() statements seem to mask each other in some way I don't understand.
mov axis,#0
mov pinStp,pinStp0
mov pinDir,pinDir0
wrlong #0,adrTime
debug ("MainLoop")
'waitct1
rep RegLoop,#NumAxes ' output all pin states AFAP
altd axis,#freq
wypin freq,pinStp
testb oldDir,axis wc
drvc pinDir ' DIR = sign of oVel before phase correction
add pinStp,pinInc
add pinDir,pinInc
add axis,#1
RegLoop
'addct1 timeCnt,timePer
rdlong timeCnt,adrTime wz
if_z jmp #RegLoop
mov oldDir,newDir
setq #NumAxes
rdlong nPos,adrRd ' read nomPos[] + filterLen
mov ptra,adrRd
add ptra,#(NumAxes+1)*8 ' block pointer
mov ptrb,ptra
add ptrb,#BlockSize*NumAxes*4 ' buffer pointer
add bufInx,#1
cmp bufInx,filtLen wc ' can't use incmod, filtLen can change on the fly
if_ae mov bufInx,#0
mov tmp,bufInx
mul tmp,#NumAxes*4
add ptrb,tmp
mov axis,#0 '#NumAxes-1
AxisLoop
' process filtering and moving flag
setq #BlockSize-1
rdlong block,ptra ' swap in block
debug ("Test1")
rdlong nVel,ptrb
sub fSum,nVel
alts axis,#nPos ' fSum-= oldest vel from buffer
mov nVel,nPos
sub nVel,oPos wz
if_nz mov fCnt,filtLen ' if nVel != 0 fCnt = filtLen
add oPos,nVel
add fSum,nVel ' fSum+= newest vel
wrlong nVel,ptrb++
cmpsub fCnt,#1 wc ' flag = --fCnt >= 0
bitc flags,axis ' update moving flag
debug (sdec (axis, nVel, fSum))
abs tmp,fSum wc
qdiv tmp,filtLen ' nVel = fSum / filtLen
getqx nVel
negc nVel wcz ' restore sign, C = new sign
getqy tmp
debug ("Test2")
sumc fSum,tmp ' add signed remainder to fSum
I would expect that this outputs something like
Cog1 MainLoop Cog1 Test1 Cog1 axis = 0, nVel = 1, fSum = 1 Cog1 Test2
However, only the MainLoop and Test2 messages appear. Test1 and axis = 0... are missing. There are no jump labels in between and the rest of the code is actually working and calculates the correct results so I assume that every instruction is actually executed.
If I comment out the debug ("Test1") and debug ("Test2") then debug (sdec (axis, nVel, fSum)) works as expected and prints out Cog1 axis = 0, nVel = 1, fSum = 1. What's going on here? ![]()
I get the same results using PropellerTool and FlexSpin so I don't think it's a compiler problem. Full source code attached.
Yep, seems like you've found a bug in the debugger. Even at low baud it still does the same. I think Flexspin's BRK debug code uses Chip's sources so no surprise both compilers perform the same way.
Thanks Evan for confirming this. A bug in the debugger is very annoying. I don't want to blame anybody. I make stupid mistakes all the time. That's why I need a debugger.
I'm curious what causes this unpredictable behaviour. I'll try to add delays or try the other debug mode of FlexSpin.
Unfortunatelly, -g debugging doesn't work for assembler in FlexSpin. It only supports debugging in Spin code where debug() statements are then converted to printf-like commands. Adding a delay before or after debug() doesn't help either.
And on a related note, I didn't realize you could use multiple comma separated inputs with sdec/udec/etc. I see that is documented halfway down the list in "Things to know about the DEBUG system", but not in the debug statements details. Neat!
I just use printf() straight. Never seriously used any debugger. My pasm code has this sort of entry:
#ifdef _DIAG loc ptrb, #dbuf wrlong pb, ptrb++ #endifand later:
#ifdef _DIAG wrword lat, ptrb++ #endifIf I need PTRB for main code then I'll change to using LOC PA, #array+offset for each debug store.
Then I have a debug dump routine I call after the dust settles, eg:
static void cmddiag( void ) { uint32_t i = _rev(dbuf[0]); printf( "CMD%d %08x%04x\n", (i>>24) & 0x3f, i, _rev(dbuf[1])>>16 ); }Yes, I have done something similar to debug time critical stuff where data transfer over the serial port would add too much delay. But I'd like to get the BRK style debugging to work, anyway. It is simpler to use and works even if the code crashes in the middle between debug actions.
Today, I tried to simplify the test code as much as possible. Surprisingly, if I replace nearly all of my code with NOPs all debug() outputs are shown correctly. So either my code is faulty or some special instructions trigger a bug in the compiler.
DAT ORG StepDirEntry mov adrTime,ptra add ptra,#4 MainLoop wrlong #0,adrTime debug ("MainLoop") RegLoop rdlong timeCnt,adrTime wz if_z jmp #RegLoop mov axis,#0 debug ("Test1") nop debug (sdec (axis, nVel, fSum)) nop debug (sdec(tmp)) nop debug ("Test2") nop debug (sdec (aVel, fRem)) nop jmp #MainLoopI'll put my code in, again, step by step and see when the problems begin to re-appear.
AAArrrrgghhh! It's the REP instruction.
rep RegLoop,#NumAxesdoesn't work,rep #RegLoop,#NumAxesdoesn't, either.rep #7,#NumAxesfixes it. Wasn't REP supposed to work with labels? I thought so. I have to disassemble it to look what machine code the compiler actually generates.Grrr, one more example of how the combination of my bad memory and lack of good documentation can lead to a lot of wasted time and frustration.
I knew REP should work with labels but forgot the exact details. REP is still not included in the P2 Assembler Language Manual. But it's here (thanks Ada). So "@" does the trick, not "#". And it's also mentioned that REP stalls interrupts including the BRK interrupt used by debug(). So leaving out the important "@" lead to REPing too many instructions which blocked some the debug()s. Good to know that nothing spooky happened and there is no compiler bug.
I missed that too. The # didn't stand out to me. I've always known to use an @ but I can't remember why Chip chose it over the #. It is an anomaly in Pasm2.
@does more than#andrep @label,repsis simpler thanrep #label-($+1),repsorrep #label-$-1,repsI don't see that as a reason for a new syntax. The REP's label just needs a special case calculation during compiling is all.
This does sound like another case where it would be nice for the compiler to emit a warning, since it's pretty rare for someone to want to say
rep foo, #barwhenfoois a label with code following it. I've added such a warning to flexspin just now.Good idea. And
REP #foo, #baralso could be in that warning.Oh, actually it is, I just forgot to mentionn that case
Yes, a warning is a good idea. There are so many cases where a single character can make the difference between working perfectly and total desaster. Working on different projects in Spin1 Spin2 and C at the same time makes it even harder...
But as soon as you do it right it works as expected.
Nice and smooth acceleration nearly without phase jitter. Opposed to interrupt based step/dir generation the duty cycle is always 50% and direction only changes while step is low. So setup/hold time problems and narrow pulses are avoided.
