P1 software PASM DAC — Parallax Forums
Hello,
I'm looking for a DAC PASM software solution for the P1.
I only found ADC (PASM) and PWM (SPIN).
  • Hi,
    Pwm plus a RC Filter does the trick.
  • evanhevanh Posts: 17,235
    edited 2024-06-24 07:21
    Filtered PDM (duty-cycle counter mode) is far better than filtered PWM. PWM filters noisily in the mid-level range, worst when set at 50%, therefore it requires an oversized capacitor to compensate. This of course makes the filter response much slower. Whereas PDM has consistence noise at all set levels, allowing for an optimised filter.
    edited 2024-06-24 10:44
    Here's an example using counterB. It's configured for 0 to 10000. If you prefer 16-bit resolution then just delete the scaling line from dacset().
    PUB  tester | val
        dacinit( 16 )    ' pin #16 has R-C filter attached
        repeat
            repeat val from 0 to 10000
                dacset( val )
            waitms( 500 )
            repeat val from 10000 to 0
                dacset( val )
            waitms( 500 )
    PUB  dacinit( pinnum )
        ctrb := %00110 << 26 | pinnum    ' DUTY single-ended
        dira := 1 << pinnum    ' enable pin drive
    PUB  dacset( percent )    ' PDM percentage in hundreths of percent
    { duty = 4G * percent / 10000
        percent := (||percent << 16 + 5000) / 10000 <# $ffff    ' scaled and bounded
        frqb := percent << 16 | percent    ' 16bit -> 32bit
    PUB  waitms( duration ) | timer, msec
        timer := cnt
        msec := clkfreq >> 10    ' one millsecond
        repeat duration
            timer += msec
            waitcnt( timer )
    edited 2024-06-24 13:00
    Oops, small bug - DIRA should be OR'd with rather than overwritten.
        dira |= 1 << pinnum    ' enable pin drive
    or clearer still
        dira[pinnum] := true    ' enable pin drive
