Wayback Machine
Forum Member @Publison maintained a repository he called the Wayback Machine in which he stored posts from previous editions of the Forums. Does anyone have a copy of this? I have some XBee modules that date back ten or more years ago that I would like to be able to utalize. I need the code an documentation that was available when these were new.
Jim
If you're using the Propeller, I have API-1 objects that I use at work.
Waybackmachine is a site
I never had much luck with it though.
How about a useful reply? .. Just select the year you want to go back to and the month time frame that a "snapshot" was taken
https://web.archive.org/web/20030315000000*/https://www.parallax.com/
Here is the xbee company:
https://www.digi.com/products/embedded-systems/digi-xbee/rf-modules
The Wayback Machine, aka Internet Archive, is a long standing resource that has been recording copies of webpages from across the Internet almost from the beginning of the Web. Definitely not maintained by Publison. He would have just provided links to it from time to time.
RS_Jim,
There is also the "Getting Started with Xbee" text and code.
https://web.archive.org/web/20130517065337/http://www.parallax.com/tabid/829/Default.aspx
https://www.parallax.com/package/getting-started-with-xbee-rf-modules-text-and-code/
I've sent donations to both Internet Archive (Archive.org) and Wikipedia since I use them all the time.
Thanks all for the input. I am a week or so away from any test with outside interference being in the way. Will report back when I get a chance.
Jim
