Can the empty space on Flash be used to store settings
in Propeller 2
When flashing any program to the flash with Proptool, Flexprop, Tachoz etc
is the flash empty space left intact, or erased each time?
I have a handful of values that I prefer to store in flash if possible
The next question would be how to see how much space is on the flash for such user data, and then how to W/R some test data starting at the extreams of the flash space.
Finally, JonnyMac described in a post that the Flash chips have some unique serial that can be read, anyone know how to do that in a few lines of code.
Andy, I save and load configuration items to and from SD and I am sure you can do the same with flash. Here is the memory structure and how I load and save those values. If I need to add a new config item, which I did, I place the new config variable after the last one, and then update the last one in the read/write data object to determine how many bytes to load.
I highly suspect you can do a similar thing with Chip's Flash filesystem.
Here is a link to the flash filesystem.
https://obex.parallax.com/obex/p2-flash-filesystem/
The attached demo will get you started. If you want to write and read standard files, Chip wrote a file system for the flash that is maintained by Steven Moraco. You will find threads about it with a quick search.
