Latest _BOOT_P2.BIX, January 2024 on the P2 Edge Rev D? — Parallax Forums
on Sourceforge
https://sourceforge.net/projects/tachyon-forth/files/TAQOZ/binaries/
I found a new BIX image from January, 06 2024.
Unfortunately it shows only:
BOOTING.... CARD: SANDISK SD SH32G REV$80 #2962451868 DATE:2023/4
then it hangs.
Same Hardware, SD-card etc. as with the BIX file from April 2021.
Also using a new SD (SanDisk Max Endurance 32 Gbyte), re-formating etc. doesn't help.
Is the new software expecting any hardware, that doesn't exist on the P2 Edge Rev. D with the P2 Edge Mini Breakout?
Markus
  • RossHRossH Posts: 5,757
    edited 2024-02-18 21:57
    A couple of suggestions:
    1. If you are using Windows, try the official SD Association format program instead - https://www.sdcard.org/downloads/formatter/ - I have had problems with Windows formatted SD cards.
    2. Try an SD card other than a SanDisk. I don't have any Max Endurance cards, but I know their Ultra cards have problems.
    Ross.
  • @MGreim ,
    take a look at the https://sourceforge.net/projects/tachyon-forth/ again. Peter has updated the BIX file most recently. That, perhaps, will fix your issue with reading from SD.
  • Hello Macieck,
    Hello Peter,
    many thanks - that BIX file works fine! :)
    It seems that the clock frequency was reduced to 200 MHz.
    Quote from _BOOT_P2.TXT:
    240219 - Loaded new image but set clock to 200MHz in case some SD cards and pcbs have problems with higher than 50MHz SPI frequency.
    Now the complete new boot message is:
    KERNEL:  TAQOZ Forth for Parallax P2 Multicore MCU   V2.14.0  'CHIP' 230821-1050  Prop_Ver G 200MHz
     MODULES:
       1912 *TEXT*
                VGA BMP TEXT 190800-0000
       1304 *BMV*
                BMV VIDEO PLAYER 190800-0000
        774 *WAVE*
                WAVE AUDIO FILE PLAYER 190800-0000
        764 *BMP*
                BMP FILE VIEWER 190800-0000
       2994 *MEDIA*
                TAQOZ INTERACTIVE MEDIA - AUDIO, TEXT, IMAGE & VIDEO DRIVERS 231119-2300
       2790 *DISK*
                SD DISK REPORTING & FORMATTING TOOLS 190800-0000
       5430 *FILE*
                TAQOZ FAT32 FLAT FILE SYSTEM for SD CARD plus VIRTUAL MEMORY  240105-1800
        132 *MATHS*
                MATHS EXTRAS - 231025-0000
       4946 *P2ASM*
                TAQOZ INTERACTIVE ASSEMBLER for the PARALLAX P2 - 210124-1200
       1802 *SPIRAM*
                LY68L6400 8MB SPI RAM ACCESS 191020-0000
       1836 *DECOMPILER*
                A decompiler for TAQOZ 190825-0000
        860 *UBI2C*
                EFM8UB3 I2C COMMANDS 210118-0000
        762 *RTC*
                RV-3028 RTC DATE and TIME 190800-0000
        930 *SMARTPINS*
                SMARTPIN FUNCTIONS and drive modes 190800-0000
        376 *P2CLOCK*
                P2 CLOCK CONTROL 190800-0000
       3948 *ANSI*
                ANSI TERMINAL SUPPORT 200410-0000
       1490 *EXTEND*
                Primary kernel extensions for TAQOZ 231111-1930
       6230 *SPIFLASH*
    MEMORY MAP
      CODE:
            0C3AA  50,090 bytes
      NAMES:
            1B725  18,455 bytes
      DATA:
            02919  969 bytes
      ROOM:
                   62,331 bytes
    HARDWARE
      PCB
            P2
      CLOCK IN
            20.000000MHZ
    CONFIG
      VGA PINS:
            0 1 2 3 4
      AUDIO PINS:
            6 7
    DEVICES
      SD CARD
            31.9GB  SANDISK   SD SH32G REV$80 #2962451868 DATE:2023/4
    I2C DEVICES
    STATS
            cpufreq: 200MHz  systicks: 2,371
    As written:
    SD: SanDisk Max Endurance 32 Gbyte
    HW: P2 Edge Rev. D with the P2 Edge Mini Breakout board
