Can't get the FAT32 object to create a new file
Hello all,
I can't create a file on a SD card, I'm using the Parallax terminal to validate the output, but it just dies when it is new file time. I am using prop tool ver. 2.9.3 and the P2 edge. I have attached ( what I thought was) simple test code. What mistake am I making?
Rob.
You're calling FATEngineStart with the fifth parameter set to the write-protect pin (-1), when that parameter actually affects the readOnly setting. Set to anything other than 0 and you can't write to the card.
Give this a try, it worked for me:
fat.FATEngineStart(_SD_DO, _SD_CLK, _SD_DI, _SD_CS, 0) fat.mountPartition(0) fat.newFile(string("test.txt")) fat.closeFile() fat.openFile(string("test.txt"),"w") fat.writeString(string("this is file test.txt")) fat.closeFile() fat.openFile(string("test.txt"),"r") fat.readData(@buffer,fat.fileSize()) debug(zstr(@buffer))That worked, Thanks!
