Upload from putty...
frank freedman
in Forth
Getting back to FORTH after a too long break. If I wanted to add or write a something-process.fth, I think there was a way to just upload the module using putty, just can't find my notes on that or a how to after much searching for this. If anyone knows how or knows the link to the how to do this that would be most appreciated. Thanks...
Answer: Take the easy way out. Use Tera Term. But recommend using the download on sourceforge. The first one I downloaded from another site had a little feature called collector. Some sort of reporting software. Did not install. Flushed. Norton did not even warn on this one. Also Source Forge has a later version.
