Updated 1080p 2bpp tiled VGA driver — Parallax Forums
  • RaymanRayman Posts: 16,461
    Here are screenshots of them working
    640 x 480 - 82K
    640 x 480 - 80K
    640 x 480 - 77K
    640 x 480 - 80K
    640 x 480 - 86K
    640 x 480 - 161K
    edited 2023-12-31 00:33
    The mixed signal scope can be useful for looking at P2 pins.
    Top two are in analog mode and bottom six are in digital mode.
    One can also play around with smartpin settings.
    Also the View/Set Pins button is interesting.
    Here are some pics to show how to use them with Eval or SimpleP2++ boards.
    480 x 640 - 193K
    480 x 640 - 142K
    edited 2023-12-31 00:30
    Way it works is the screen is divided into 120 columns and 68 rows of 16x16 pixel tiles (only top half of lowest row is visible).
    Each tile has a pointer that either points to an embedded font character or optionally, to 2bpp graphics area.
    Each tile also has a set of four colors (this is two bits per pixel, so each pixel in a tile can only be one of these four colors), from a selection of 256 colors.
    The 256 color palette can be changed, if needed, but the current ones should work for most cases.
    Multiple fonts are supported, but showing that needs some archeology. Addition of special characters to the fonts are also supported.
    When used without graphics, the hub ram footprint is very small, considering it is in 1080p.
    It needs 3 cogs (5,6,&7) for regular use and 4 cogs when graphics are needed. Note that cogs 6&7 share their LUT, so have to be adjacent.
    There is a special, cogless form of the graphics driver that uses free cycles on one of the VGA cogs. But, this only works with FlexProp at the moment, so is not shown here.
  • Very usefull. Also love that you added some pictures herr on the forum
  • RossHRossH Posts: 5,780
    Looks good. Thanks for updating it!
    Ross.
  • Wonderful that but where do you define the pins to use.
    edited 2024-01-24 17:06
    This can be a challenge, right? Why the SimpleP2 board might make things easier, where the pins are constant.
    Anyway, for the 1080p_TileDriver_MixedScopeDemo, the USB basepin is defined in 1080p_TileDriver_MixedScopeDemo.spin2, here:
    CON 'USB mouse pin settings
      USB_BASE_PIN    =16              'led for USB activity
    The VGA basepin is defined in VGA_1080p_8c, here:
    CON
      intensity = 80'100    '0..128
      vga_basepin     =8 '0 'First pin used by EvalBoard A/V Accessory with VGA and audio
    I think that's all you need for that one...
    This is assuming you have a P2 Eval type setup, using the accessory boards on groups of 8 pins with the lowest pin being the basepin...
