M6 - bit of SMART NCO Frequency — Parallax Forums
Christof Eb.Christof Eb. Posts: 1,584
edited 2023-10-26 15:12 in PASM2/Spin2 (P2)
I am trying to using some code from @FredBlais to output I2S at a MAX98357A.
https://github.com/speccy88/TAQOZ/blob/master/src/forth/audio/WAV-I2S.FTH
It sets a pin to NCO-Frequency mode and -as far as I understand- tries to output the inverted signal by setting bit14 = M6.
(Sorry for the FORTH syntax.)
%1_00110_0          := #NCO_FREQ
1 14 << NCO_FREQ OR     := #NegNCO_FREQ
*BCLK PIN #NegNCO_FREQ WRPIN
Unfortunately, if bit14 is set, then there is no output at the pin. If the bit is not set, then I can measure the output at the pin.
(Also I do not see anything to be shifted out, but that's the next step...
Edit: There must be some change in the Taqoz version for this, the active PIN get's lost. now I get at least some ugly noise...)
What's wrong here? The code is from 2019, so before the last revision. Has anything changed here?
Thanks for any hints!
Christof
  • evanhevanh Posts: 17,243
    edited 2023-10-26 23:46
    P_INVERT_OUTPUT (bit14) is not going to be a problem in itself, so you've probably got other problems.
    --- ASSIGN PINS
    14      := *LRCLK
    12      := *BCLK
    10      := *DIN
    --- SMARTPINS CONSTANTS
    %1010 24 << %1_11100_0 OR   := #SYNC_TX
    %001111             := #CONT-16BIT
    1 14 << NCO_FREQ OR     := #!NCO_FREQ
    Pin assignment is flawed. Any relative change between DIN and BCLK also requires editing the smartB relative assignment in #SYNC_TX. If BCLK is not DIN+2 then this would explain why the TX pin is doing nothing serially.
  • Christof Eb.Christof Eb. Posts: 1,584
    edited 2023-10-27 07:59
    --- ASSIGN PINS
    14        := *LRCLK
    12        := *BCLK
    10        := *DIN
    Thanks for looking into it! And thank you for the warning.
    By chance I was able to use exactly the pins 10,12,14 in my setup and there is a warning in the source code too, so this is not my problem.
    @cgracey
    The question is here, if M6 bit can be used to invert the output signal at the physical pin in NCO_Frequency mode.
    At the moment I do not set M6 and have changed the disabling to float the DIR. Also I have changed over to use local variables in the main loop which is more easy to read for me.
    https://forums.parallax.com/discussion/167868/taqoz-tachyon-forth-for-the-p2-boot-rom/p23
    WAVE FILE PLAYBACK FOR PROPELLER 2 WITH ADAFRUIT MAX98357 I2S CLASS D MONO AMPLIFIER
    CLOCK SETUP AT 80MHZ
    16 KHZ SAMPLE RATE, 16 BITS RESOLUTION
    BCLK FREQUENCY : 16KHZ * 16 (BITS) * 2 (LEFT/RIGHT) = 512KHZ
    BCLK AND LRCLK GENERATED WITH 2 SMARTPINS IN NCO FREQUENCY MODE
    WYPIN SET AT 2**32/2 = $8000_0000
    WXPIN FOR BCLK : (80E6)/(512E3)/2 = 78.125 APPROXIMATED TO 78
    200E6/512E3/2 = 195
    WXPIN FOR LRCLK : 78*32 = 2496
    195*32= 6240
    DIN SETUP IN SYNCHRONOUS SERIAL MODE
    IF YOU CHANGE DIN AND BCLK PINS, YOU NEED TO CHANGE DIN MODE CONFIG
    DIN CLOCK PIN IS SETUP AT PIN + 2
    LINKS :
    https://learn.adafruit.com/adafruit-max98357-i2s-class-d-mono-amp/pinouts
    https://cdn-learn.adafruit.com/downloads/pdf/adafruit-max98357-i2s-class-d-mono-amp.pdf
    https://cdn-shop.adafruit.com/product-files/3006/MAX98357A-MAX98357B.pdf
    http://soundfile.sapp.org/doc/WaveFormat/
    --- ASSIGN PINS
    14      := *LRCLK
    12      := *BCLK
    10      := *DIN
    57 := dLedPin
    \ %AAAA_BBBB_FFF_MMMMMMMMMMMMM_TT_SSSSS_0
    %1010 24 << ( B-input: x010 = relative +2 pin's read state 1= inverted )
    \ %0010 24 << ( B-input: x010 = relative +2 pin's read state )
    1 14 << NCO_FREQ OR     := #NegNCO_FREQ \ war 14
    \ : DISABLE_I2S         *LRCLK LOW *BCLK LOW *DIN LOW ;
    : DISABLE_I2S           *LRCLK FLOAT *BCLK FLOAT *DIN FLOAT ;
    : ENABLE_I2S            *LRCLK HIGH *BCLK HIGH *DIN HIGH ;
    --- SMARTPINS SETUP
    : !PINS
        DISABLE_I2S
        *LRCLK PIN #NCO_FREQ WRPIN ( 2496 )  6240  WXPIN $8000_0000 WYPIN
        *BCLK PIN #NCO_FREQ WRPIN ( 78 ) 195  WXPIN $8000_0000 WYPIN
        *DIN PIN #SYNC_TX WRPIN #CONT-16BIT WXPIN
    \ Am Ausgang: MSB von Left kommt zuerst, (der syncTx mode schickt LSB first)
    \ letzte 2 LSB bits werden noch übertragen, nachdem LRCLK gewechselt hat.
    \ ausgegeben wird von der Platine default (L+R)/2
    : seekDATA ( -- addr ) \ seek for the data header in WAV
       0
       begin
          1+
          dup sd@
       $61746164 = until \ "data" reverse
       \ sdPointer !
    pre PLAY ( <filename> -- )
        [C] FOPEN
       key drop
    --- WAVE DATA START AT ADDRESS 44, PRIME SYNC SERIAL SHIFTER
        44  DUP SDW@  REV 16>>
       ( addr data16 ) DUP 4* WYPIN
       ( addr data16 ) DUP 14 >> SWAP
       ( addr data2 data16 )
        ENABLE_I2S
       ( addr data2 data16 ) DUP ( addr data2 data16 data16 )
       -ROT 4* OR WYPIN 14 >>
       ( addr data ) SWAP 2+ WAITPIN
    --- ADDRESS 40 IS SUBCHUNK2SIZE
        ( 40 )
          drop
          seekDATA dup 4 +
          SD@ 2/ 2 - ( subchunksize )
    --- EXIT ON KEY PRESS OR EOF
        FOR
          i 12 >> dLedPin PIN!
          ( olddata addr ) DUP SDW@
          \ 15 sign 32768 +
         \ drop  $f  ( dup . )
         REV 16>> SWAP
         ( olddata data16 addr ) -ROT ( c b a -- a c b )
         ( addr oldddata data16 ) DUP
         ( addr oldddata data16 data16 ) -ROT
         ( addr data16 olddata data16 ) 4* OR
         *DIN PIN WYPIN WAITPIN
         ( addr data16 data2 ) SWAP DUP
         ( addr data2 data16 data16 ) -ROT
         ( addr data16 data2 data16 ) 4* OR WYPIN 14 >> SWAP
         ( data2 addr ) 12 + WAITPIN
          KEY
        ?NEXT
       crlf @PIN .
       fclose
       DISABLE_I2S
    : i2sOutLoop {: addr# samples# , data16# data2# -- }
       samples# for
          addr# SDW@
          \ drop $F \ test
          REV 16>> to_data16#
          *DIN PIN
          data2# data16# 4* or  WYPIN WAITPIN
          data16# 14 >> to_data2#
          \ data16# 14 >> to_data2#  \ data2# is already there
          2 \ 2 for mario.wav
          +to_addr#
          key
       ?next
    ; forgetLocals
    pre playI2s
       !PINS
        " mario.wav" FOPEN$
       key drop
        ENABLE_I2S
        ( 40 )
          drop
          seekDATA dup 4 +
       i2sOutLoop
       drop \ old data
       crlf @PIN .
       fclose
       DISABLE_I2S
    \ playI2s
    If I output $f I get the following picture, which seems to be OK. Yellow is data, blue is LRCLK. The signals change at high-low of the clock and the last 2 bits of LBS are still transferred after LRCLK changes. The timing of these phases is stable.
    (It's the first time, that I play with I2S, so I am not completely sure.)
    If I transfer real data, I can faintly hear some good signal burried in lots of noise.
    edited 2023-10-27 08:33
    Ah, it must be only one last bit send after LRCLK changes!!!!
    Mario is playing now without noise.
    200E6/512E3/2 = 195
    195*32= 6240
    LINKS :
    --- ASSIGN PINS
    14      := *LRCLK
    12      := *BCLK
    10      := *DIN
    57 := dLedPin
    --- SMARTPINS SETUP
    : !PINS
        DISABLE_I2S
    \ letztes LSB bit wird noch übertragen, nachdem LRCLK gewechselt hat.
       0
       begin
          1+
          dup sd@
       \ sdPointer !
       samples# for
          addr# SDW@
          \ drop $F \ test
          REV 16>> to_data16#
          *DIN PIN
          data2# data16# 2* or  WYPIN WAITPIN
          data16# 15 >> to_data2#
          2 \ 2 for mario.wav
          +to_addr#
          key
       ?next
    ; forgetLocals
    pre playI2s
       !PINS
        " mario.wav" FOPEN$
       key drop
       ( addr data16 ) DUP 2* WYPIN
       ( addr data16 ) DUP 15 >> SWAP
        ENABLE_I2S
       -ROT 2* OR WYPIN 15 >>
        ( 40 )
          drop
          seekDATA dup 4 +
       i2sOutLoop
       \ i2sOutSin
       drop \ old data
       crlf @PIN .
       fclose
       DISABLE_I2S
    \ playI2s
    Still wondering, if there was a change in the behaviour of M6 which might perhaps explain, that this old code does no more work.
    edited 2023-10-27 09:23
    Looking at those scope traces, inverting BCLK will phase shift it with respect to the LRCLK. That might screw with which data bit gets clocked first into each I2S channel.
    EDIT: Doing a little reading, I'm surprised to find the data is meant to lag behind the LRCLK by one BCLK. It's different to what I remember from a couple a decades ago. I was reading AC97 specs that had it as LSbit first, but the modern chips seem to be MSbit first now. Same as SPI.
    So that means the data trace above is one BCLK late. Inverting BCLK could shift the data later still.
    edited 2023-10-28 06:36
    Ah, it's simple a typo! #NCO_FREQ and NCO_FREQ ! :s
