Bit shifting left on P1 PASM — Parallax Forums
My goal was get the status bit 30 in a variable.
I used SHL instruction so it goes into C flag.
if W has a value 0x80000000
SHL W,#2 WC
The C flag would always equal 1
The Propeller Manual says the C flag is set equal to Value’s original bit 31.
Does that mean shift of the number of bits, except 0, would result in C equal to 1 because bit 31 was set at the start of instruction ?.
My mind was in 68000 mode, thinking the number of bits shifted would go into C flag would work, but no.
A work around was to do two shl
SHL W,#1
SHL W,#1 WC
  • Wuerfel_21Wuerfel_21 Posts: 5,856
    edited 2023-09-25 13:42
    The C flag is always set to the original MSB of the shifted register, even if your shift count is zero. (same applies to right shifts, except they give you the LSB)
  • JonnyMacJonnyMac Posts: 9,829
    edited 2023-09-25 14:08
    If you have other bits to check, you could create a mask (at the end of PASM code, before RES declarations)
    BIT30                   long      1 << 30
    then use AND to check it. With only one bit in the mask, C will contain the state of the tested bit.
                            and       t1, BIT30             wc, nr
    With NR, the tested variable is not modified.
    BIT30                   long      1 << 30
    Thanks for that, I did not think of doing that way.
    I suppose the TEST instruction does the same thing.
  • Yes, TEST is identical to AND with NR flag. (conversely, you can write TEST with a WR flag to get AND). I find TEST easier to read.
    edited 2023-09-25 15:34
    Indeed -- and I should have remembered that given I used the word 'test' in my reply! :D
    Agree.
                            test      t1, BIT30             wc
