How to access a variable that a pointer pointed to? /flexbasic — Parallax Forums
There is an example in documentation:
  var x = new ubyte(10)  ' allocate 11 (not 10) bytes and return a pointer to it
  x(1) = 1               ' set a variable in it
How to
  var x = new ubyte  ' allocate 1 byte and return a pointer to it
  (????)= 1                     '   set a variable in it
  • evanhevanh Posts: 17,308
    Why not just use a single compile time declared variable? The usual reason to allocate from heap or stack is for large runtime filled arrays.
  • pik33pik33 Posts: 2,419
    edited 2023-06-23 16:00
    This question is the side effect of problems with passing and returning classes and multiple valuse to/from functions. I tried a workaround involving passing/returning a pointer to temporary allocated variable, then I realized that I don't know how to access a variable having a pointer in FlexBasic (in normal way, not with acrobations using poke and cast, or treating a variable as one-element array). In C you use * to do this, in Pascal there is ^, something should be here, too.
  • Dereferencing a pointer in BASIC is always done with array notation, like p(0) (or p(1) if you have set 1 as the default array base).
    However, for passing variables to subroutines and functions it's much easier to use byref parameters than pointers. That is, instead of:
    function expr(ct as integer) as expr_result, integer
      return t1,ct
    end function
    a,ct = expr(ct)
    do
    function expr(byref ct as integer) as expr_result
    a = expr(ct)  ' ct is updated to the new value by expr
    The byref will cause ct to be passed "by reference", which means internally a pointer to the variable will be passed and changes to ct inside the function will affect the caller's variable.
    edited 2023-06-24 00:05
    Ah, right. This is why Chip made Spin without type checking. He much preferred assembly's freewheeling over C's myriad of referencing syntax (and presumably Pascal's too).
  • MicksterMickster Posts: 2,935
    edited 2023-06-24 11:36
    Hope I'm not hijacking the thread but do we have code pointers in FlexBasic or have I missed it?
    I realise that we have On-Gosub but is this a jump table?
    Craig
    We have pointers to functions/subroutines; is that what you meant?
    Yes, on-gosub and on-goto (and select/case) are implemented internally with a jump table, if appropriate (the compiler tries to guess whether a jump table or series of if statements would be more efficient).
  • @ersmith
    Oh the select/case is interesting...I'll test it
    :+1:
    Craig
