P2Si65 - A Path for P2 to Software, Multitasking, OS, …? - Work in Progress — Parallax Forums
Motivation
Based on a P2 a Self-Hosted Computer might be built.
It should have:
A File System (SD Card)
Multitasking to control something or take measurements
A console user interface
A compiler
An Assembler
Access over WLAN
Plenty of useful Software
If we look at this list, we can see, that Peter Jakacki's Taqoz has nearly all of it. Access over WLAN can be achieved with a ESP-01 Module. Only the last item is not given.
Peter has included a 6502-Simulator in his Source Forge archive.
So the basic idea is:
Have a 6502-Simulator inside Taqoz Forth.
Can we use that to gain access to software?
Old software was often written in assembler to get the speed.
64kBytes of HUB Ram should be plenty for 6502 and still fit nicely into Hub Ram.
Speed must be as fast as an original Computer to be fun: 6502 running at >= 1MHz.
How it went so far
A very first test with the simulator, which is written entirely in Forth, was encouraging. Each assembler code is a Forth word. Very transparent. It worked and it was able to achieve about 0,4MHz with a minimal loop:
$3000 INC $2000
$3003 JMP $3000
Getting rid of debugging code brought it over 1MHz easily. So I decided to go on.
Next part was to bring some little software to it. WOZMON is a famous compact peace of code by Steve Woziak for the Apple I. There is an enhancement, which brings a mnemonic assembler and a disassembler.
AppleI_Manual.pdf (chez.com)
So this peace of code brought to light much to learn for me (My experience with 6502 is rather lowlevel as I never owned one of these computers. - …A carry flag, that alters it's meaning…) and some bugs. Console input and output is done via an unused code $FF which is now TaqozTrap. It can be included easily into any assembler code ".byte $FF". I decided to follow: http://www.z80.eu/dos65/DOS-65_System_Interface_Guide_A.pdf
3rd step should bring more test code for debugging and some more knowledge about speed. So I was glad to to stumble over:
https://www.ele.uva.es/~jesus/onthe6502.pdf which gives a benchmark for the "sieve". - This showed a speed back to 0.3MHz. :-( .
Speed was improved over many smaller steps, which made debugging more easy.
Introducing new Methods brought the steps:
Some Hub assembler code
Bring 6502 Registers and constants into cog Ram
Bring assembler routines into LUT Ram
Last step: A self-repeating main loop word in LUT assembler, which does call Forth words.
4th step was now an additional program to find bugs. It is a "Very Tiny Language 2". It is very impressing once again, what can be acieved with less than 1kByte! A IDE with an interpreter.
Manual:
VTL-2 (altair680kit.com) http://www.altair680kit.com/manuals/Altair_680-VTL-2 Manual-05-Beta_1-Searchable.pdf
Newer Source by Michael T. Barry:
6502-Assembly/VTLC02 at main · barrym95838/6502-Assembly · GitHub
Used Source:
GitHub - Klaus2m5/VTL02: Very Tiny Language for the 6502 series of CPUs
Tools:
A powerful cross assembler:
cc65 - a freeware C compiler for 6502 based systems: https://cc65.github.io/
The linker/assembler creates a listing file with the hex codes. I wrote a routine, which extracts the hex codes with their addresses and inserts them into the 6502 Hub Ram Page.
Kowalski Simulator, a powerful simulator and debugger:
Daryl's Computer Hobby Page (rictor.org) https://sbc.rictor.org/kowalski.html
This is very helpful to find out, what is going on. (Oh, yes, nearly all bugs are my very own…)
At the moment I am wondering, how to go on, after these steps so far. One attractive possibility seems to be EhBasic.
Enhanced 6502 BASIC – Retro Computing (hansotten.nl): http://retro.hansotten.nl/6502-sbc/lee-davison-web-site/enhanced-6502-basic/
Another possibility seems to be a part - emulation of the BBC computer, because this seems to have a clear interface to some sort of BIOS. It's BASIC is powerful and structured.
What would be the best route to make much software (I am not much of a gamer....) accessible for P2?
Any hints appreciated!
Christof
  • mparkmpark Posts: 1,336
    6502 @ 1.4MHz? Awesome! And that VTL-2 language is cute!
  • Some update.
    After some more debugging, it is now capable to run the full blown Enhanced 6502 Basic! - About 10kBytes of 6502 assembler code.
    retro.hansotten.nl/uploads/leedavison/Enhanced_6502_BASIC_reference_manual.pdf
    This is a niece BASIC interpreter, which does use tokens and has fast FOR...NEXT and fast DO...LOOP UNTIL.
    I added the possibility to execute any Forth word from BASIC: The address of the string containing the word is written in Basic to $FFF4 (of 6502's memory page). If this is found by the trap routine, which is called after each BASIC command to find ctrl C, then the Forth word is executed. This Forth word can write a word to 6502's $FFF6 as a result. In the example below, "get100" gets a timer result in 1/100 secs.
    As Forth words can also be written as "code words" in assembler, full access to P2's hardware is given.
    Benchmark results for comparison can be found here: https://ia800304.us.archive.org/16/items/byte-magazine-1981-09/BYTE_Vol_06-09_1981-09_Artifical_Intelligence.pdf
    With 170 seconds for one iteration it is running faster than the interpreted Microsoft BASICS for Z80@4MHz and Apple II, which also had to use floating point numbers.
  • RossHRossH Posts: 5,720
    @"Christof Eb." said:
    Motivation
    It should have:
    A compiler
    An Assembler
    Access over WLAN
    Catalina has all these, possibly excepting "Access over WLAN", because I don't know what that means - but I'm sure it would be trivial to add. Can you clarify?
  • Fascinated and following :+1:
    Craig
    yes Catalina together with it's Lua is going in a similar direction. The main difference is, that I think, that it is a good idea to simply accept P2's "limited" HUB RAM. So no SPI RAM is used or necessary. To achieve this, Forth has to be simpler than Lua. And this BASIC interpreter is usable with 64kB or less.
    about your question:
    Here the idea is to use the serial console over WLAN TELNET, while with Taqoz's multitasking and the additional cogs, some controlling process is running in background. You can use all the possibilities of Forth in parallel to the controlling tasks: View and alter data or parameters, compile, assemble, ... Connect from a PC or mobile phone. No additional server is needed.
    I have several ESP-32 modules running here. They use a Forth based on Arduino CC. They have triple access:
    1. TELNET console as described.
    2. possibility to reprogram the ARDUINO code over WLAN
    3. They offer their file system in the WLAN as a remote storage, which can be accessed from Windows like a network disk.
    Perhaps I find a way in future, that a ESP-32 module acts as mass storage for P2 together with TELNET serial modem and network disk server.
    Christof
    edited 2023-06-21 23:49
    Christof
    Yes, I figured you would want more than just a WiFi file transfer capability (which would be easy and also gets you the ability to load software via WiFi). The others are a little more difficult, but would be do-able if you really want them.
    If you limit yourself exclusively to Hub RAM I think you may be unnecessarily limiting yourself to assembler-level and/or interpreted languages like Forth, Lisp, Basic or Spin. We already have all of those in various forms, but very few people use them other than already confirmed Propeller-heads. None of them are likely to attract hordes of new users to the Propeller. You need higher level languages to attract serious usage. And the reason is the last item on your list ...
    Bu then there is Lua. Yes, Lua is also interpreted, but on the P2 it can run entirely in Hub RAM (it can use External RAM, but does not need to). I note the ESP-32 also supports Lua, as do other microcontrollers. This is because Lua has a low footprint and is easy to port because it is written in what they term "clean C", which is essentially ANSI C. Which means once you have C you have Lua.
    So in Lua we already have on the P2 the ability to write and run software using a modern high-level language that is already used in this space, is growing in popularity and has plenty of support and software.
    If you don't like Lua as much as I do, you could choose mciroJavaScript, microRuby or microPython. It is the "micro" part that puts me off those - I wouldn't want to use anything where I didn't have access to the full language.
    So we are almost there. I notice the P2 WiFi add-on board is no longer available, but when it is again I might add support for it.
    Ross.
    Well, in my personal opinion, it is mainly Parallax Marketing policy, which prevents wide usage. The "edge board" is way too expensive for it's performance (and unnecessarily nonhandy to use without USB serial and it's special connector) and they only support their very special own language Spin2. Writing documentation has stalled. No visible efforts to write drivers.
    P2 is the only microcontroller, that I know of, which really needs an inline assembler. When I work with Arduino environment, I have never used Assembler. But with P2 it is mandatory, because you have to use tricks to reduce HUB access and to write drivers. So Lua would need an inline Assembler. Does it fully support 8 cogs?
    I have not tried your Lua, but a simple speed comparison for ESP32 was:
    C:YAFFA-Forth:Lua:Micropython = 1:22:48:145
    (((I sometimes think, that some eager politicians have banned light bulbs in Europe. I do wonder, when they will ban Micropython....)))
    Writing of speed. I yesterday coded the "Byte Sieve" with Taqoz and with it's P2 assembler. For a reduced version for the first 308primes up to 2039 (SIZE=1024) I get:
    P2 loops in assembler, executing from LUT: 0,00054sec (array is in HUB)
    P2 Taqoz Forth, algorithm original: 0,0084sec
    P2Si65, 6502 assembler: 0,858sec (version from post above)
    P2Si65, 6502 EhBasic: 20,1sec
    Actually I have to confess that the version with EhBasic is well fast enough for my personal demands of prime numbers. And doesn't it give a much better feeling, that they are calculated with floating point precision?
    Have fun,
    Christof
    With utmost respect, as a control systems developer, the Propellers are ridiculously inexpensive and those of us who are mediocre programmers can realise mind-blowing capabilities using a "toy language" such as FlexBASIC.
    In contrast, one of my clients has asked me to source a backup for his discontinued PLC (puny compared to even a P1) and the best price I can find on eBay is £1800 (8-DI and 8-DO)
    There is also an expansion module for reading two quadrature encoders (500,000 counts/sec) and this is £500 (used).
    By definition, the Propellers are "controllers". They don't claim to be "computers".
    I love these bad-boys :+1:
    Craig
    Lua is designed to be highly integrated with C. When you need more speed than Lua offers, you first drop into C. From there you can drop in to inline assembler if you really need to, but that would be quite rare.
    Catalina includes a multi-processing version of Lua which can use all 8 cogs.
    Speed is never going to be one of Lua's strong points. However, for C programmers (and there are lots of those) Lua is still an attractive option. Lua finds much of its use as an embedded scripting language inside larger C programs, because by doing so you can have the speed of C and the rapid prototyping power and flexibility of Lua.
    Ross.
    .... lots of stuff
    ah, ok, guys. now I know that your chatter in my recent PLC thread are echoes from here. good back ground for me. thanks for all your efforts/debates on this front. necessary to discuss when there is so much potential.
    I had forgotten about this thread :)
    A couple of points of progress:
    1. Catalina has now added the ability for C/Lua programs to execute across multiple Propellers. So a "cluster" of multiple Propellers (either running Lua or C) is now possible, and this is another way of getting around the 512Kb Hub RAM limit of a single Propeller (i.e. no need for XMM RAM).
    2. I've ordered the Parallax WiFi add-on board for the P2, and expect to be adding a WLAN plugin to Catalina soon. Not sure what serial protocol I will support yet - Telnet is relatively easy (I've implemented it in the past) but is a very old protocol. Suggestions welcome!
    Ross.
  • refaQtorrefaQtor Posts: 186
    edited 2025-01-05 23:58
    what bus is needed, what protocol are you using across it?
    errr. I supposed I could find that in the docs?
    You could. Look at the document "Aloha from Lua". The ALOHA protocol is a trivially simple protocol - just complex enough to support RPCs between one master Propeller and up to eight slave Propellers - see aloha.h and aloha.c in demos/elua/aloha for full protocol details.
    ALOHA currently runs across one or more serial ports (the 8 port limit is due to the use of the 8 port serial plugin, not the protocol itself) , but it could also be used across the multi-propeller parallel bus I have under development ... but which I never seem to get enough time to finish. In practice, the serial connection would be fast enough for most purposes when used from Lua. It can also be used from C - see amaster.c and aslave.c in the same directory.
    Ross.
  • ErNaErNa Posts: 1,851
    There is no "best" programming language. And this chatters all the efforts to pieces. I believe in object oriented programming, but in a little different way as the common understanding, is, because I do not understand common understanding ;-) So I stay with SPIN and ASM for the propeller whenever possible.
    Otherwise I would have used FORTH, just because I like reversed polish notation, that is in some respect, stack machines since my HP45 (1600,--DM at those time, had to tap all sources of money that time).
    My concept is like follows: There are operators that act on data structures. An operator is fed with a data stream, where the meaning of the data is known by convention or by self-description (like done in JSON).
    The propeller allows for 8 processes to run concurrently. Interrupts allow for more processes to run virtually in parallel. To me a process is seen as "running in real -time in parallel, if I can not decide by observation, if this is the case.
    On very low level I implemented a process control block following conventions, so cogs can access to variables that allow communication. This is very limited and not optimized at all, but it allows cogs in different chips to communicate, so the network has not real limits.
    With the P2 I have "infinite" memory available, in the past I always had to eliminate procedures currently not used, what limited flexibility. This now is no longer the case, with larger flash memory or SD it is even possible to dynamically load procedures.
    This just what comes to my fingers as I read through this thread, I intend to continue in the Propeller Code SPIN2 ASM folder
