YModem (over serial port) for P2 — Parallax Forums
RaymanRayman Posts: 16,460
edited 2023-06-04 21:25 in Propeller 2
Just converted the P1 version to P2.
Seems to work.
Tested with Tera Term.
Can be useful if don't want to remove uSD card from P2 board.
Not exactly fast though...
Note: You have to program this to flash and boot from flash for this to work because Tera Term resets P2.
  • RossHRossH Posts: 5,780
    Hi Rayman
    Catalina's Catalyst SD card operating system and also the payload and comms serial terminal emulators also implement YMODEM. Their implementation is compatible with Tera Term, so I think they should also work with your implementations.
    I use them for exactly what you suggest - to avoid having to continually put in and take out the uSD.
    Ross.
