Propeller 1 with MCP2221a not detected on COM port — Parallax Forums
Hey all,
I'm pretty new to the Propeller and I'm trying to piece together a simple board with a propeller and MCP2221A USB to UART/I2C converter. I've wired it on a breadboard with all the necessary connections and checked voltages with a multimeter. For the life of me I can't get my windows machine to detect the Propeller. It shows up as COM7 but downloading code always fails.
The MCP2221A doesn't have a "reset trigger" signal so I manually ground the reset pin on the propeller low when uploading, yet it still doesn't work.
If anyone can point me in the right direction that would be great.
Thanks!
  • jmgjmg Posts: 15,200
    @ieatsoupwithafork said:
    I'm pretty new to the Propeller and I'm trying to piece together a simple board with a propeller and MCP2221A USB to UART/I2C converter. ... The MCP2221A doesn't have a "reset trigger" signal
    Why choose such a primitive and slow UART part, when it only makes life more difficult ?
  • @jmg it was the only part available in DIP form, and I like prototyping with thru-hole parts.
    Ah...
    You can get tiny modules from AliExpress with USB_UARTS mounted and USB connectors fitted.
    Look for parts like CP2102N, CH9102, CH343, CH340, CH9340, PL2303GC, etc modules and choose one that is not too pin-starved. (ie has reset ability)
  • maccamacca Posts: 1,054
    That's the reason: the upload protocol has precise timing, I don't think you can start the upload at the precise time after reset (milliseconds, not seconds...).
    Unless it is possible to assign DTR to an output pin, I don't think that part is usable in this context.
    If you have a PIC18F14K50, I wrote a USB-Serial firmware here specifically for a P1 prototype board:
    https://github.com/maccasoft/propeller-dev-firmware
    It is basically the cdc_basic sample from Microchip MLA with some changes, I think it can be easily converted to other parts.
    You actually can, it's not that precise. I used to be able to do it with ~80% accuracy. You have to hold in your reset button, start the compile/upload, then release it at the right time.
