Strategy of converting C multi-dimensional constants to Spin 2 DAT structures.
ke4pjw
I am attempting to convert a c program for Arduino to a Spin 2 program.
Is this a good strategy to represent a multi-dimensional array of byte constants in memory for Spin 2?
static const uint8_t NUM_ERROR_CORRECTION_BLOCKS[4][40] = {
// Version: (note that index 0 is for padding, and is set to an illegal value)
// 1, 2, 3, 4, 5, 6, 7, 8, 9,10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40 Error correction level
{ 1, 1, 1, 2, 2, 4, 4, 4, 5, 5, 5, 8, 9, 9, 10, 10, 11, 13, 14, 16, 17, 17, 18, 20, 21, 23, 25, 26, 28, 29, 31, 33, 35, 37, 38, 40, 43, 45, 47, 49}, // Medium
{ 1, 1, 1, 1, 1, 2, 2, 2, 2, 4, 4, 4, 4, 4, 6, 6, 6, 6, 7, 8, 8, 9, 9, 10, 12, 12, 12, 13, 14, 15, 16, 17, 18, 19, 19, 20, 21, 22, 24, 25}, // Low
{ 1, 1, 2, 4, 4, 4, 5, 6, 8, 8, 11, 11, 16, 16, 18, 16, 19, 21, 25, 25, 25, 34, 30, 32, 35, 37, 40, 42, 45, 48, 51, 54, 57, 60, 63, 66, 70, 74, 77, 81}, // High
{ 1, 1, 2, 2, 4, 4, 6, 6, 8, 8, 8, 10, 12, 16, 12, 17, 16, 18, 21, 20, 23, 23, 25, 27, 29, 34, 34, 35, 38, 40, 43, 45, 48, 51, 53, 56, 59, 62, 65, 68}, // Quartile
static const int8_t NUM_ERROR_CORRECTION_BLOCKS[4] = {
1, 1, 2, 2
Converts to:
NUM_ERROR_CORRECTION_BLOCKS ' // Version: (note that index 0 is for padding, and is set to an illegal value) byte 0, 1, 2, 3, 4, 5, 6, 7, 8, 9,10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40 Error correction level byte 1, 1, 1, 1, 2, 2, 4, 4, 4, 5, 5, 5, 8, 9, 9, 10, 10, 11, 13, 14, 16, 17, 17, 18, 20, 21, 23, 25, 26, 28, 29, 31, 33, 35, 37, 38, 40, 43, 45, 47, 49 ' Medium byte 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 4, 4, 4, 4, 4, 6, 6, 6, 6, 7, 8, 8, 9, 9, 10, 12, 12, 12, 13, 14, 15, 16, 17, 18, 19, 19, 20, 21, 22, 24, 25 ' Low byte 2, 1, 1, 2, 4, 4, 4, 5, 6, 8, 8, 11, 11, 16, 16, 18, 16, 19, 21, 25, 25, 25, 34, 30, 32, 35, 37, 40, 42, 45, 48, 51, 54, 57, 60, 63, 66, 70, 74, 77, 81 ' High byte 2, 1, 1, 2, 2, 4, 4, 6, 6, 8, 8, 8, 10, 12, 16, 12, 17, 16, 18, 21, 20, 23, 23, 25, 27, 29, 34, 34, 35, 38, 40, 43, 45, 48, 51, 53, 56, 59, 62, 65, 68 ' Quartile
And accessed as byte[@NUM_ERROR_CORRECTION_BLOCKS + (rows*40) + cols]
Does this make sense? These arrays have me a bit noodled.
(Edited to ensure that [0][0] existed)
(Edited again because I left some data out)
The C code there is illegal, the two arrays have the same name.
But in general, yes, that's about the way to do multi-dim arrays.
I thought that too, but somehow it works? I hate the Arduino coding style. Takes too long to peel back all the layers. I assumed it would set byte 0 of each row to the values listed.
I am attempting to convert this code:
https://github.com/ricmoo/QRCode
https://wokwi.com/projects/318641692720759379
No, you copypasted the code wrong (???), the bigger array has a different name.
EDIT: no wait there's a preprocessor thing going on, but still, copypasted wrong
Arduino code is just C++ with some "shortcuts" and simplifications, like no need to declare functions in advance (sources are pre-processed to add declarations).
And just like C and C++, array elements are numbered from 0 (don't understand your assumption, Arduino doesn't insert hidden data...).
The code use preprocessor directives to use one or the other array definition (LOCK_VERSION value, whatever it means), then seems you have used a commented row as data (guess is a copy / paste error).
Nope, more likely should be converted to this:
OK, so I see the top row I pasted was just wrong.
Now the 2nd declaration of NUM_ERROR_CORRECTION_BLOCKS in c code. What's happening there? Or s that cruft reassigning 1,1,2,2 to the first 4 columns of row 4?
static const int8_t NUM_ERROR_CORRECTION_BLOCKS[4] = { 1, 1, 2, 2 };It is a completely different array. The first is a 4x40 array, the above is a 4 elements only. It doesn't "reassign" anything. The preprocessor directive selects which one is defined, I guess somewhere in the code it handles the difference based on how LOCK_VERSION is defined (I know nothing about the barcode decoder so I don't know what the differences are...). The online code viewer seems to do a good job in locating all ocurrences of LOCK_VERSION, nice.
Oh, got it. Ug. A whole meta configuration at build time. Yuck.
