P2 Taqoz V2.8 TRACING of a Variable: Serial Output of Return Chain and Stack
Hi, this might perhaps be useful for others, groping because of mysterious trouble.
It uses absolute addresses of serial routines and cog, so they are fix here for the version! **So this will only work with the version _BOOT_P2.BIX in Taqoz.zip in https://sourceforge.net/projects/tachyon-forth/files/TAQOZ/binaries/ .
The assembler routines from TRACE are used here, so it should work, even, if the Forth system is defective.
It is meant for cog0.
What does it do?
While haunting some tricky bug, I tried to use TRACE! The problem was, that this can output very much text. So the question was, if this can be modified with a trigger to output text only, if something more specific has happened. Here a variable is monitored. If it's value is altered, an output is generated:
1. the Variable's Value
2. Instruction Pointer after the change and it contents
3. The chain in the return stack
4. The depth and contents of the parameter stack.
The new routine is patched into the code of the original TRACING routine (not instead), which starts at $440. This TRACING routine on the other hand is patched instead of doNext into the cog code by TRACE!. So we can control the modified TRACING routine with the same means as the original.
Other ideas for interesting triggers?
Have Fun, Christof
TriggerTrace.fth
19.04.23 Christof Eberspaecher
!polls \ clear multitasking
IFDEF *Tests*
oldorgT org
FORGET *Tests* }
pub *Tests* PRINT" P2 Test" ;
0 bytes oldorgT
' TRACE
00420 ff000002 TRACE rdlong doNext,##TRACER ' Replace 1st instruction of doNEXt with a call to TRACING'
00424 fb046230
00428 f607de00 mov traceL,#0
0042c fd64002d ret ' !!! use discrete ret to delay before returning to doNEXT'
00430 fda00440 TRACER call #\TRACING
00434 ff000002 UNTRACE rdlong doNext,##TRACING
00438 fb046240
0043c fd64002d ret
00440 TRACING
00440 fae41f61 rdword x,PTRA++ ' read word code instruction
00444 f213f1ef cmp PTRA,traceL wc
00448 cd64002d if_c ret
0044c fdb00184 call #DBIP ' PRINT IP '
00450 fdb000a4 call #DBNAME ' PRINT NAME'
\ Timer event and toggle pin P2 Docu Page 51 uses cog register deltaR
57 := ledPin
$1c := deltaR
$fdb00184 := call_DBIP \ original in $44c
long aVariable
aVariable := trAddr \ <<<<< set variable address here
long oldVariable
oldVariable := oldVar
$0f := x
$1ee := xreg
$17 := retptr \ return stack pointer
$15 := auxptr
$5d4 := prtIP
$4bc := prtHex
$0a4 := prtName
$5f8 = prtCrlf
code trigTrace ' trace when variable changes
rdlong r1,##trAddr
rdlong xreg,##oldVar
cmp r1,xreg wz '
if_z ret ' nothing happened
mov xreg,r1
wrlong xreg,##oldVar ' update
call #\$4bc ' print Variable value
mov r1,retptr
push x
call #\$5d4 ' prt IP
call #\$5f8 ' crlf
.l1 ' from top of return stack
mov xreg,retptr ' stack position
call #\$4bc
rdlut xreg,retptr ' address
sub xreg,#2
call #\$4bc
rdword xreg,xreg ' word code
mov x,xreg
call #\$4bc ' print word code
call #\$4f8 ' print word name
call #\$5f8 ' crlf
cmp retptr,#$40 wz
if_nz sub retptr,#1
if_nz jmp #l1
call #\$5f8 ' crlf
call #\$454 ' print stack
call #\$5f8
pop x
mov retptr,r1
ret
end
' trigTrace 2 + := tTraceAddr \ get asm start address
: startTrig
$FD80_0000 tTraceAddr + \ JMP absolute
$44c ! \ patch into TRACING
: stopTrig
call_DBIP
: trigTest
nop
%red %pen
0 aVariable !
KEY drop
begin
aVariable ++
500 ms
KEY until
%white %pen
startTrig
' trigTest TRACE!
