mysterious ifdef/define error in FlexSpin
Maybe it is my fault misunderstanding it or I stumbled over something.
I have a main spin file where I define either of one
define W5100
define W5200
define W6100
in the same file I can do this in the object section
OBJ
ifdef W5100
wiz : "ms_W5100.spin2"
endif
ifdef W5200
wiz : "ms_W5200.spin2"
endif
ifdef W6100
wiz : "ms_W6100.spin2"
endif
cool.
now the main file uses other objects also including the wiznet driver
So main includes "socket" and socket includes also the wiz and I can do the same and it recognizes the define and selects the correct driver.
main also includes "dns" and dns also includes socket. And here it gets borked.
so MAIN-SOCKET-WIZ works
but MAIN-DNS-SOCKET-WIZ does not and socket does not now about the define and does not find the correct WIZ
To me it looks like the define is valid in main and all included objects of main but not inside objects inside of those.
what do I do wrong?
MAIN, SOCKET and DNS have the same code like above in the OBJ section.
#define
only has any effect in the source file where it happens -- it isn't carried over into any sub-objects. All of the preprocessor commands work similarly to how they do in C, namely they go on a file by file basis.You can get a define in all files by doing it on the flexspin command line (with -DSYMBOL=x).
that explains my trouble...
