Shop Learn P1 Docs P2 Docs Events
FlexProp: memory management of structs — Parallax Forums
If I define a struct, for simplicity say containing 5 longs, do I have any guarantees how that will be structured in memory? Will it be 5 sequential addresses? If I need a specific mem layout is it better to define an array and use offsets?
  • ersmithersmith Posts: 5,659
    If all the variables are longs then they will be laid out in memory the same way they are in the struct. If some of the variables are shorter, then there may be gaps introduced to make the longer variables be aligned on their "natural" boundaries (e.g. if there is a word and then a long, 16 bits of padding will be put between them to make the long start on a 32 bit boundary).
  • That's what I was hoping you'd say. :)
