debug statement weirdness — Parallax Forums
jay_harlowjay_harlow Posts: 43
edited 2023-01-26 23:44 in PASM2/Spin2 (P2)
Propeller Tool 2.9.2
Where did the debug("hello ", ubin(mask), ubin(match)) output go?
I don't see it
  {Object_Title_and_Purpose}
  DEBUG_LOG_SIZE = 65536
  'debug_main = true
CON
  _clkfreq = 180_000_000
  IO = 0
  pinCAN_INT    = IO + 4 ' INT
VAR
  long  stack1[6]
PUB Main() | mask, match
  mask := decod pinCAN_INT
  match := decod pinCAN_INT
  cogspin(NEWCOG, Collector(), @stack1)
PUB Collector() | cs, clk, sdo, sdi, index
  debug(`LOGIC MyLogic TITLE 'CANBUS I/O' SAMPLES 256 'Index' 1 gray 'CLK' 1 ORANGE 'CS' 1 MAGENTA 'SDO' 1 RED 'SDI' 1 BLUE)
  'repeat
    index += 1
    CLK := index // 2
    CS :=  trunc(getrnd()) // 4
    SDO := trunc(getrnd()) // 4
    SDI := trunc(getrnd()) // 4
    debug(`MyLogic `udec_(index, CLK, CS, SDO, SDI))
  cogstop(CogId())
  • evanhevanh Posts: 17,252
    Use three back-ticks to quote code.
    Try adding a repeat below the cogspin(NEWCOG, Collector(), @stack1)
  • hey thanks, much better now.
      'debug_main = true
    CON
      IO = 0
    VAR
      long  stack1[6]
      repeat
        index += 1
        CLK := index // 2
      cogstop(CogId())
  • I found a simple workaround
      debug(if(true), "hello ", ubin(mask), ubin(match))
    Which demonstrates a new limitation:
    debug(if(my_flag), `MyLogic `udec_(index, CLK, CS, SDO, SDI))
    I would like to turn the myLogic line on and off, just like other debug statements.
    Jay
