Spin2 language proposal: anonymous objects
Basically, it's a way to access a sub-object without having to name it, or equivalently to directly include the sub-object's methods and variables into the parent object. It's easiest to give an example; let's suppose we have a Serial object with methods startx() and str() that we want to include in our program:
OBJ _ : "Serial" ' using the placeholder _ as name includes Serial as an anonymous object ' now Serial's methods may be accessed directly PUB main() startx() ' calls Serial.startx str(msg) ' calls Serial.str(msg)
This serves two purposes:
(1) Like Pascal's WITH or Python's FROM ... IMPORT, it lets you refer to the sub-object methods without having to name the sub-object, removing a bit of syntactic clutter.
2) It provides a kind of simple inheritence scheme for objects.
Implementation-wise, it could be done in a number of ways. A simple one might be to just auto-generate methods for the parent, i.e. the above snippet would be exactly equivalent to:
OBJ __anon__ : "Serial" PUB startx() __anon__.startx() PUB str(s) __anon__.str(s) PUB main() startx() str(msg)
A slightly more sophisticated implementation would re-write the method calls, so references to the object's startx
method would automatically be replaced by __anon__.startx()
It'd be perfectly reasonable to allow only one anonymous sub-object to be present in any given parent object.
@cgracey, thoughts?
Crickets? I guess this feature isn't too interesting, so I haven't documented it, but flexspin 5.9.25 does implement it.
This sounds like it would be good for things to seem like they're more "built-in", like a string manipulation object (C standard lib?) or something. You'd get the benefit of it being a reusable object, but it'd seem more transparent.
