Pnut/PropTool 2.9.2 Bug? (POLXY) — Parallax Forums
Today I installed the new version 2.9.2 of PropTool (over the 2.7.0) and the following code is giving a different result:
CON
  _clkfreq = 200_000_000
PUB main()|l, x, y, degree
  degree := $80000000 / 180 '32bit degree unit
  l := 1
  x,y := POLXY(l, 45*DEGREE)
  debug(udec(l), sdec(x), sdec(y))
debug shows:
Cog0  l = 1, x = 536_870_880, y = -1_073_741_823
Same code in 2.7.0 gave
Cog0  l = 1, x = 1, y = -1
  • @cgracey and @"Jeff Martin" : this appears to be a regression in PNut. The output doesn't change even if the first parameter to POLXY is changed from 1 to 1024. PNut v35q gives sensible answers, but PNut v37 does not. Unfortunately those are the only PNut versions I have to try with.
    (flexspin agrees with the older PNut, for what it's worth.)
  • evanhevanh Posts: 17,317
    edited 2023-01-14 03:15
    Pnut v35v is good.
    Pnut v36 is good.
    There is a discrepancy with the sign of degree in Flexspin. Pnut treats $8000_0000 as a signed negative value while Flexspin is unsigned.
  • @evanh said:
    Pnut v35v is good.
    Pnut v36 is good.
    You should probably update your flexspin. From v5.9.22 on FlexSpin agrees with PNut that $8000_0000 is negative.
    Right, got it. :)
  • I verified that the POLXY() routine was modified in the v37 Spin2 Compiler, but don't know why. I noted this and tagged Chip in the P2_PNut_Public repo to follow-up.
    Sorry about this. I had forgotten to use a #immediate in the interpreter when comparing which instruction we were executing. I've fixed this, but need to push it.
    In the spin2_interpreter.spin2 file:
        cmp pa,bc_polxy
    ...needs to become...
        cmp pa,#bc_polxy
    That will fix this problem.
      cmp pa,bc_polxy
      cmp pa,#bc_polxy
    Is there an updated version of Propeller Tool that has this fix? Haven't been able to test the new features in my project because of this error.
        cmp pa,bc_polxy
        cmp pa,#bc_polxy
    Sorry for the delay. I will get a new version out in the next day. It will be v38.
  • @cgracey said:
      cmp pa,bc_polxy
      cmp pa,#bc_polxy
    No worries @cgracey I appreciate you taking the time to fix it. Thanks!
  • @cgracey said:
      cmp pa,bc_polxy
      cmp pa,#bc_polxy
    Will this also fix the repeat control value issue?
    @JonnyMac said:
    @cgracey said:
        cmp pa,bc_polxy
        cmp pa,#bc_polxy
    Yes.
    edited 2023-02-03 21:08
    I posted a new version (v38) that fixes the POLXY/XYPOL/ROTXY bugs and leaves var = final +/- step after a REPEAT-var.
    https://forums.parallax.com/discussion/171196/pnut-spin2-latest-version-v38-bug-fixes-repeat-var-now-leaves-var-past-final-value/p1
  • @cgracey Could you explain a bit better the change to the REPEAT-var loop? I just noticed that my POLXY code does work as expected with v38, but now another portion of the code is broken and I strongly suspect that the culprit could be the REPEAT-var change, but I don't honestly understand what it is about. Could you provide an example to illustrate the change?
    edited 2023-05-03 07:00
    A couple of years back there was a request to change it. Chip has just changed it back to original.
    • The nominal and current way is to have the iteration variable at loop exit as a value one greater than the final used value. Ie: It uses a typical post-increment mechanic within the repeat loop.
    • The previous way, as per that request, was to have the completed loop exit value be same as the final used value within the loop.
  • @evanh
    Got it!
    Had to scrub through all my project files to find the three instances where I was adding 1 to the last value of i in the REPEAT i from 0 to some_number-1, to get the total number of executions.
    Thanks!
