Shop Learn P1 Docs P2 Docs Events
Duplicating the EEPROM — Parallax Forums
Is there a way to set up the propeller to replicate the EEPROM to a 2nd EEPROM?
If I have my programmed EEPROM on P28 and P29, but want to hook up a second blank EEPROM, say to pins P26 and P27, could I have the propeller take the programming from the programmed EEPROM and copy it to the blank one?
So, this would be a standalone EEPROM programmer, you pop in a blank, turn on the circuit, it gets programmed, then you can remove it to use on other propellers.
