question about using a pushbutton switch with a propeller
I want to build a circuit with the push buttens supplied by parallax and can't find a schematic of how to connect one. I know it take two switches to do. Can anyone help me, an already existing schematic from anything would be fine. would be fine.
Take a look at parallax professional development board p/n 32111 schematic.
I found it thanks
Just an FYI in case you have a need.
There are many debounce solutions but this is one of my favorites:
http://www.fruitoftheshed.com/MMBasic.Switch-de-bounce-uses-Ganssels-Algorithm-for-Zero-Delays.ashx?HL=debounce
Craig
Hello!
They also make debounce circuits. The MC14490 is one such example. Also Maxim makes several varieties, they used to send their samples to practically anyone, but that changed a while back and I found fault with their logic, but did not complain. You might be able to find those parts via DIgi-Key as it happens.
Mascot asleep.
https://www1.parallax.com/downloads/propeller-education-kit-labs-fundamentals-text
https://www1.parallax.com/downloads/propeller-education-kit-labs-fundamentals-example-code
