Propeller is not recognized ?
I have a propeller WX activity board and XBee S2C unit is plugged inti XBee socket and is powered with 9V DC.
When I try to run discover hardware via propeller tool, NO propeller chip is detected.
But when I remove the XBee the Prop tool detects the prop chip.
There is no other hardware is attached to the activity board WX.
I need some help to remedy this issue. I read somewhere a solution - RTS/CTS reset ?.
but I am unable to find it.
Thank you,
siri
Maybe the Xbee is plugged in the wrong way. Or something is shorted and dragging power supply down.
Check the WX board docs. With the XBee plugged in, the board might be expecting uploads to occur from a WX module. But there's a jumper selection available to override this automatic redirection.
@DigtalBob - the XBee is plugged in correctly - the association and Wx led are both lit.
Thanks for your reply.
@"Phil Pilgrim"
Thank you for reply I will check the activity boards documentation.
Siri
@"Phil Pilgrim"
your correct the answer the issue was there in the activity wx board.
" connect the SEL socket to ground."
Thank you once again.
siri
