C64 Theremin — Parallax Forums
C64 Theremin
PublisonPublison Posts: 12,366
edited 2022-09-02 08:54 in General Discussion
Linus is at it again, (no props this time).
https://www.linusakesson.net/hardware/theremin/
He did a wonderful demo with the P1 here:
https://www.linusakesson.net/scene/turbulence/index.php
li
  • There's a big difference in quality between the original Theremin's sine waves and the square waves burped out by the C64.
  • @"Phil Pilgrim (PhiPi)" said:
    Theres a big difference in quality between the original Theremin's sine waves and the square waves burped out by the C64.
    Agreed. I have played a couple of MOOG units back in the 80's and 90's.
    GENIUS! Love this. Amazing Grace never sounded so good.
    @Whit needs to play this in his church!
  • pik33pik33 Posts: 2,419
    edited 2022-11-19 22:14
    So I got 2 555s and solder one of these (2 needed) lft's 555 contraptions. It works, generating something about 500kHz. Instead of C64 I connected the output to a P2 and made a quick program using one of my audio drivers. It plays (whatever waveform I want), I can change the audio frequency with my hand over a piece of wire.
    To do: solder the second 555 to control the volume, make the real program for a P2, add several encoders to adjust "zero beat" and ranges.
    Then I wonder if it is possible to make a theremin with a P2 and nothing else...
  • that Goerzel demo from chip may give hints to do so.
