ADC question
in Propeller 2
fltl pin wrpin ##( P_ADC | P_ADC_GIO ), pin wxpin #%00_1101, pin wypin #0, pin dirh pin waitx ##( 8192 << 2 ) rdpin callo_tmp, pin fltl pin wrpin ##( P_ADC | P_ADC_VIO ), pin wxpin #%00_1101, pin wypin #0, pin dirh pin waitx ##( 8192 << 2 ) rdpin calhi_tmp, pin
I used this bit of code to read the 0v and 3.3v on one of my analog inputs, but the level measured for 0v was around 2-3K counts which I found odd. And the 3.3V level was around 13K counts. Why is the spread between these so small when using 14 bit SINC2 sampling mode?
14 bits, max count is 2^14=16384. The scaling resistors allow for reading a little beyond the rails, so the 0v and 3.3v inputs are provided to calibrate the input levels. Being a sigma/delta type, the ADC is not a "multiplying" ADC, so it doesn't scale relative to supply voltage.
Here's a write-up I did - https://forums.parallax.com/discussion/comment/1484327/#Comment_1484327
It's not exactly how the ADC works but is a rough analogue. Basically there is a virtual ground at VIO/2 with scaling resistors. At x1, the scaling is roughly a 5.0 Volt span. There is measurable current pulling to VIO/2, and is higher at higher gains. The exact circuit is here - https://forums.parallax.com/discussion/comment/1510744/#Comment_1510744
This block diagram might also be of interest - https://forums.parallax.com/discussion/171420/smartpin-diagram-now-with-p-p-bit-mode-table
PS: And this too - https://forums.parallax.com/discussion/174441/measuring-floating-pin-voltage-adc-from-just-the-built-in-comparator/p1
