Compile SPIN code from Flexprop — Parallax Forums
disha_sudradisha_sudra Posts: 43
edited 2022-08-02 14:10 in PASM/Spin (P1)
Hello,
How can I call SPIN function in CPP file in Flexprop?
How to compile any sample SPIN code in Flexprop?
I'm trying to compile sample code given in below link.
https://github.com/totalspectrum/flexprop/blob/master/samples/blink1.spin2
  • JonnyMacJonnyMac Posts: 9,831
    edited 2022-08-02 16:58
    That demo you cite is Spin2, and works as-is (I just tested). Here's a similar program for the P1 -- if you have a FLiP or PAB you can run without any other hardware.
    con
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
      CLK_FREQ = (_clkmode >> 6) * _xinfreq
      DELAY    = CLK_FREQ / 4
    con
      LED2 = 27
      LED1 = 26
    pub main | t
      outa[LED2..LED1] := %01
      dira[LED2..LED1] := true
      t := cnt
      repeat
        outa[LED2..LED1] ^= true
        waitcnt(t += DELAY)
  • @disha_sudra said:
    Hello,
    Load the Spin file into a C struct, something like:
    // create C structure from the Spin2 blink demo
    struct __using("blink1.spin2") my_blink;
    void main() {
        // call the demo() function from blink1.spin2
        my_blink.demo();
    Just use File > Open to open the Spin file in the editor, and then Compile & Run (for P1 or P2 as appropriate). The language used is based on the file extension: .spin for Spin1, .spin2 for Spin2, .bas for BASIC, .c for C, .cpp for C++ (which is only partly supported).
  • Thank you.
  • RaymanRayman Posts: 16,430
    I think flexprop can compile spin2 code for P1, is that right?
    Yes, as long as no P2 specific hardware features are used.
