Comparing an array to non-array should generate a warning.
pik33
This simple code:
dim a as ulong(4) dim b as ulong a(0)=1 b=2 if a=b then b=3
compiles without a warning and I didn't even know what this does (except it makes a hard to find error in a bigger piece of code)
What is the result of comparing array to non-array? A warning should be generated there ("dont do it unless you really know how this works")
Using just an array in a comparison will test against the address of the array. There should have been a warning there, I'll add it.
