Fast byte swapping?
I'm dealing with network packets and have to swap a lot of bytes.
I thought the REV instruction might help, but looks like in P2 it's bits and not bytes, which isn't what I need. I know having the commands inline would remove the function call overhead, but without something more succinct it would create a mess with how many times I'm calling it.
PUB FlipWord(bytein):byteout|a,b,c,d
a := (bytein>>24)&$FF
b := (bytein>>16)&$FF
c := (bytein>>8)&$FF
d := (bytein)&$FF
byteout := (d<<24)|(c<<16)|(b<<8)|a
There isn't any sort of spin intrinsic for it, but the movbyts assembly instruction is exactly what you need:
If you're using flexspin, you can use asm/endasm instead of org/end and it will be able to inline the function
Here are the pure Spin versions I've been using in my network stack, but @Wuerfel_21 's inline ASM version is better and I'll rewrite my two functions to use
movbyts
instead.For the P2 you need to declare a return variable.
I frequently do timing tests on little bits of code and decide to compare inline PASM against pure Spin in two forms.
The results:
It's quite different in FlexSpin. PASM with org - end is here the slowest, because the 2 instructions must be copied to the cogram and then executed (like in Chips Spin2). But with ASM - ENDASM the compiler generates the PASM code really inline and executes it with hubexec.
Results:
Andy
Thanks all, really informative!
Hello JonnyMac and kwagner,
I have posted my spin2 method to reverse the order of bytes in a long value.
HydraHacker
