3$ mp3 player
I received a microbit mystery box recently and two of the items it contained were a microbit v1.5 and an amp/speaker Parallax #32781 so I thought I would put them together in a small project. The project I chose was a simple mp3 player with a microbit controller. The player I bought was
https://www.amazon.com/dp/B09GPC4VXS?ref=ppx_yo2ov_dt_b_product_details&th=1
There are quite a few modules out there that call themselves DFPlayer but they don't all have the same IC's or the same serial command set and maybe other differences. The mp3 player I am using is labelled mp3 tf 16p v3.0, and this is the reference I worked with
https://usermanual.wiki/Manual/DFPlayerMiniManual.234442183/pdf
The set up I have now is behaving reliably, it is great for many sound effects such as laser sounds, machine gun sounds, monster howls for use with robots or halloween ghosts/monsters, if you have a Youtube account you can download lots of these sound effects copyright free from youtube studio. For the demo I am using a couple of music clips. MP3 clips should be named 001.mp3 002.mp3 003.mp3 ..... etc. etc.
The micro python code has 5 methods controlled from a single button (button A). One press initializes the mp3 player after that one press toggles between play and pause, two presses selects the next track and 3 presses selects the previous track. This configuration can easily be changed if you have another preference.
Any questions and I will attempt to help.
from microbit import *
import microbit
import time
microbit.uart.init(baudrate=9600, tx=pin2)
start = 0
end = 0
elapsed = 0
count = 0
initialized = False
playing = False
Start_Byte = 0x7E
Version_Byte = 0xFF
Command_Length = 0x06
End_Byte = 0xEF
Acknowledge = 0x00
def player_init():
write_to_player(0x09, 0, 1) # initialize source (TF)
def player_pause():
write_to_player(0x0E, 0, 0)
def player_play():
write_to_player(0x0D, 0, 0)
def player_next():
write_to_player(0x01, 0, 0)
def player_previous():
write_to_player(0x02, 0, 0)
def write_to_player(cmd, arg1, arg2) :
buffer = []
checksum = 0
checksum = -(Version_Byte + Command_Length + cmd + Acknowledge + arg1 + arg2)
chk_0 = checksum & 0xFF
chk_1 = (checksum >> 8) & 0xFF
buffer = bytearray([Start_Byte, Version_Byte, Command_Length, cmd, Acknowledge,
arg1, arg2, chk_1, chk_0, End_Byte])
microbit.uart.write(buffer)
while True:
if microbit.button_a.is_pressed():
start = time.ticks_ms()
microbit.sleep(100)
if start != 0:
end = time.ticks_ms()
elapsed = end - start
if elapsed >= 500:
end = 0
elapsed = 0
start = 0
count = microbit.button_a.get_presses()
if count == 1 and not initialized:
player_init()
count = 0
initialized = True
elif count == 1 and not playing:
player_play()
playing = True
count = 0
elif count == 1 and playing:
player_pause()
playing = False
count = 0
elif count == 2 and playing:
player_next()
count = 0
elif count == 3 and playing:
player_previous()
count = 0`
