Accessory boards 2x06 female pin header
ManAtWork
in Propeller 2
I'm looking for the right pin headers that are on every accessory board. At the end of the schematics of the universal motor driver board there is a part list. It says "4UCON: 21289" for J100 and J102. However, I can't find that part on the 4UCON website. I think part no. 21008 looks good. It's an SMT female 2x06 pin header with bottom entry. It also has the two centering posts that I can see at the bottom view of the accessory boards.
Can anybody confirm that this is the right header or suggest an alternate part?
21008 is the same part, just without the pick-n-place cap. If you need the cap then ask them for a quote on our "custom" part number - they are a pretty helpful bunch.
Another alternative for lower quantity / local suppliers : Harwin : M20-7810645 / M20-7810645R
Thanks. I have a bunch of 2x13 headers here left over from other projects. I'll cut them in half to get 2x6 headers. Should be OK for my low quantity needs. I just want to make sure that the PCB layout if compatible with what Parallax uses.
