Boe-Bot Troubles and Questions — Parallax Forums
Evan_PetersenEvan_Petersen Posts: 3
edited 2022-04-16 21:58 in BASIC Stamp
I currently have a project for my class that requires me to build the boe-bot, it has navigate through a course using a predetermined path. I insereted the exact code below which is straight out of the handbook (Chapter 4 EEPROM Navigation). When I try to run the code onto my bot it sends an error message stating that the constant exceeds 16 bits, while highlighting the 01234567 in the EEPROM data. Does anyone know how to fix this? Im using the BS2 model and version 2.5.
' Robotics with the Boe-Bot - EepromNavigation.bs2q
' Navigate using charachters stored in EEPROM.
' {$STAMP BS2}
' {$PBASIC 2.5}
' {$PORT COM3}
DEBUG "Program Running!"
pulseCount      VAR   Word
address         VAR   Byte
instruction     VAR   Byte
      Address: 0123456789
DATA           "FLFFRBLBBQ"
FREQOUT 4, 2000, 3000
DO UNTIL (instruction = "Q")
  READ address, instruction
  address = address + 1
  SELECT instruction
    CASE "F": GOSUB Forward
    CASE "B": GOSUB Backward
    CASE "L": GOSUB Left_Turn
    CASE "R": GOSUB Right_Turn
  ENDSELECT
LOOP
END
Forward:
 FOR pulseCount = 1 TO 64
   PULSOUT 13, 850
   PULSOUT 12, 650
   PAUSE 20
 NEXT
 RETURN
Backward:
   PULSOUT 13, 650
   PULSOUT 12, 850
   PAUSE 20
 NEXT
 RETURN
Left_Turn:
 FOR pulseCount = 1 TO 24
   PULSOUT 13, 650
   PULSOUT 12, 650
   PAUSE 20
 NEXT
 RETURN
Right_Turn:
   PULSOUT 13, 850
   PULSOUT 12, 850
   PAUSE 20
 NEXT
 RETURN
  • Evan_Petersen,
    You code is Chapter 4, Activity #6 except for the comments.
    The line with Address and the Vertical Pipes (|) are comments so there should be an apostrophe (') in front of them, just like the first few lines of the program.
    Comments are ignored but since the apostrophes are missing, the editor thinks that it should be using that huge number so you get an error.
    You can copy and paste the programs from the PDF.
    https://www.parallax.com/package/robotics-with-the-boe-bot-kit-downloads/
  • Thank you very much, I had no clue there were pdf files for them.
  • Evan_PetersenEvan_Petersen Posts: 3
    edited 2022-04-16 21:57
    I have another problem if anyone could help...
    So I have finsihed the eeprom navigation code to the specifications needed for my maze (listed below). My next objective is to add the whiskers to it. When the whiskers make contact i want the bot to pause and then turn slowly the opposite way until the whisker istn making contact anymore. So in otherwords if the Right whisker is triggered then the right wheel will go forward and the left wheel will go backwards and the opposite if the left whisker is triggered. When no whiskers are triggered i want it to continue on with program ive created. Ive been trying to use the roaming with whiskers file but i cant figure out how to have it return to the eeprom code. Roaming with whiskers is also provided below under the maze code.
    ______MAZE CODE_______
    ' {$PORT COM3}
    ' {$PBASIC 2.5}
    ' Navigate using characters stored in EEPROM.
    ' {$STAMP BS2} ' Stamp directive.
    ' -----[ Variables ]----------------------------------------------------------
    pulseCount VAR Word ' Stores number of pulses.
    address VAR Byte ' Stores EEPROM address.
    instruction VAR Byte ' Stores EEPROM instruction.
    ' -----[ EEPROM Data ]--------------------------------------------------------
    ' Address: 0123456789 ' These two comm ented lines show
    '          |||||||||| ' EEPROM address of each datum.
    DATA      "FRGRJLDLKLPLUQ" ' Navigation instructions.
    ' -----[ Initialization ]-----------------------------------------------------
    ' -----[ Main Routine ]-------------------------------------------------------
     READ address, instruction ' Data at address in instruction.
     address = address + 1 ' Add 1 to address for next read.
     SELECT instruction ' Call a different subroutine
     CASE "F": GOSUB Forward ' for each possible character
     'CASE "B": GOSUB Backward ' that can be fetched from
     CASE "L": GOSUB Left_Turn ' EEPROM.
     CASE "G": GOSUB Forwards
     CASE "J": GOSUB Forwardss
     CASE "D": GOSUB Forwardsss
     CASE "K": GOSUB Forwardssss
     CASE "P": GOSUB Forwardsssss
     CASE "U": GOSUB Forwardssssss
     ENDSELECT
    LOOP
    END ' Stop executing until reset.
    ' -----[ Subroutine - All Forwards ]-----------------------------------------------
    Forward: ' Forward subroutine.
     FOR pulseCount = 1 TO 270 ' Send 64 forward pulses.
     PULSOUT 13, 850 ' 1.7 ms pulse to left servo.
     PULSOUT 12, 680 ' 1.3 ms pulse to right servo.
     PAUSE 20 ' Pause for 20 ms.
     NEXT
     RETURN ' Return to Main Routine loop.
     Forwards: ' Forward subroutine.
     FOR pulseCount = 1 TO 130 ' Send 64 forward pulses.
     NEXT
     Forwardss: ' Forward subroutine
     FOR pulseCount = 1 TO 258 ' Send 64 forward pulses.
     NEXT
     Forwardsss: ' Forward subroutine.
     FOR pulseCount = 1 TO 103 ' Send 64 forward pulses.
     NEXT
     Forwardssss: ' Forward subroutine.
     FOR pulseCount = 1 TO 390 ' Send 64 forward pulses.
     NEXT
     Forwardsssss: ' Forward subroutine.
     FOR pulseCount = 1 TO 240 ' Send 64 forward pulses.
     NEXT
     Forwardssssss: ' Forward subroutine.
     FOR pulseCount = 1 TO 384 ' Send 64 forward pulses.
     NEXT
    ' -----[ Subroutine - Backward ]----------------------------------------------
    Backward: ' Backward subroutine.
     FOR pulseCount = 1 TO 64 ' Send 64 backward pulses.
     PULSOUT 13, 650 ' 1.3 ms pulse to left servo.
     PULSOUT 12, 850 ' 1.7 ms pulse to right servo.
     NEXT
    ' -----[ Subroutine - Left_Turn ]---------------------------------------------
    Left_Turn: ' Left turn subroutine.
     FOR pulseCount = 1 TO 29 ' Send 24 left rotate pulses.
     NEXT
    ' -----[ Subroutine – Right_Turn ]--------------------------------------------
    Right_Turn: ' right turn subroutine.
     FOR pulseCount = 1 TO 26 ' Send 24 right rotate pulses.
     PULSOUT 12, 820 ' 1.7 ms pulse to right servo.
     NEXT
     RETURN ' Return to Main Routine section.
    _________Romaing With Whisker________________
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    ' {$PORT COM3}
    pulseCount   VAR    Byte
    DO
     IF (IN5 = 0) AND (IN7 = 0) THEN
       GOSUB Back_UP
       GOSUB Turn_Left
       GOSUB Turn_Left
     ELSEIF (IN5 = 0) THEN
       GOSUB Back_Up
       GOSUB Turn_Right
     ELSEIF (IN7 = 0) THEN
       GOSUB Back_Up
       GOSUB Turn_Left
     ELSE
       GOSUB Forward_Pulse
     ENDIF
    LOOP
    Forward_Pulse:
      PULSOUT 13, 850
      PULSOUT 12, 650
      PAUSE 20
      RETURN
    Turn_Left:
     FOR pulseCount = 0 TO 20
      PULSOUT 13, 650
      PULSOUT 12, 650
      PAUSE 20
     NEXT
     RETURN
    Turn_Right:
      PULSOUT 13, 850
      PULSOUT 12, 850
      PAUSE 20
      NEXT
      RETURN
    Back_Up:
     FOR pulseCount = 0 TO 40
      PULSOUT 13, 650
      PULSOUT 12, 850
      PAUSE 20
     NEXT
     RETURN
    That's somewhat challenging with a BS2, which has neither hardware or software interrupts. Otherwise you would "simply" run your maze program until a whisker triggered an interrupt, when you would jump to the whiskers subroutine, which could return to your maze code when its done.
    One possible method is to send enough servo pulses to move an inch or so at a time, then check the whiskers and repeat. No need to stop really, the whisker check is likely so fast that you won't even see the bot slow down, it will coast for a fraction of a second during the check then keep going.
    One problem I foresee with your plan is that the whiskers subroutine will move your robot in random ways to get away from a wall, so when you return to your maze map you are likely headed in a different direction than before you hit the wall. After just one whisker trigger & routine, your robot is off course and it gets worse with each subsequent whisker trigger.
    Have you considered modifying your whiskers to let you follow a wall?
  • Peter167Peter167 Posts: 10
    edited 2022-04-16 20:14
    @erco said:
    That's somewhat challenging with a BS2, which has neither hardware or software interrupts...
    HI, this is the same person i just got locked out of my account and I took what you said I have changed the idea. Thank you very much for the advice!!
    I'm now working on a code that a professor has given me, using this code 5 IR sensors are used to detect the front, Front left and right, and sides left and right. I have the design down but I do have some questions on the code that my professor was unable to clear up with me. There are a few lines like this ( IF irDetectCenter = 0 THEN cent ) i get the that ir is detecting something causing a 0 but what on earth does cent mean? it says its not defined when i try to run the code but i dont know how to define it. Again, thank you for any help that you could provide:)
    irDetectLeft VAR Bit       'Variable for left
    irDetectCenter VAR Bit     'Variable for center
    irDetectRight VAR Bit      'Variable for right
    irDetectLSide VAR Bit      'Variable for left side
    irDetectRSide VAR Bit      'Variable for right side
    irDetectLSideFar VAR Bit   'Variable for left side low resistance
    irDetectRSideFar VAR Bit   'Variable for right side low resistance
    mLoop VAR Word
    Lmotor PIN 15    'The left motor is connected to pin 14, pulses go through here
    Rmotor PIN 14    'right = 15
        'speeds are -> 650-750-850
    LFast CON 850    'Conastant for left motor at full speed
    RFast CON 650    'Conastant for right motor at full speed
    LStop CON 750    'Conastant for left motor at full speed
    RStop CON 650    'Conastant for right motor at full speed
    LMid CON 830     'Conastant for left motor at medium speed
    RMid CON 700     'Conastant for right motor at medium speed
    LSlow CON 770    'Conastant for left motor at minimum speed
    RSlow CON 730    'Conastant for right motor at minimum speed
    LRev CON 650     'Conastant for left motor at full speed in reverse
    RRev CON 850     'Conastant for left motor at full speed in reverse
        FREQOUT 7, 1, 38500    'left side
        irDetectLeft = IN8
        FREQOUT 6, 1, 38500    'center
        irDetectCenter = IN5
        FREQOUT 3, 1, 38500    'right side
        irDetectRight = IN2
        FREQOUT 10, 1, 38500   'Left Close
        irDetectLSide = IN11
        FREQOUT 1, 1, 38500    'right Close
        irDetectRSide = IN0
        FREQOUT 9, 1, 38500     'left side far
        irDetectLSideFar = IN11
        FREQOUT 4, 1, 38500    'right side far
        irDetectRSideFar = IN0
       IF irDetectLSide = 0 AND irDetectRSide = 0 THEN main   'START COMMAND wave your hands past the two side detectors to start program
    Main:
    PAUSE 1000
    DO
        PULSOUT Lmotor, LFast 'left motor runs on full speed
        PULSOUT Rmotor, RFast 'Right motor runs on full speed
        FREQOUT 1, 1, 38500    'right side
        irDetectRSide = IN0
        IF irDetectLSide = 0 AND irDetectRSide = 1 THEN
           DO
               irDetectRight = IN2
            LOOP UNTIL irDetectLSide = 1 OR irDetectRSide = 0
        ELSEIF irDetectLSide = 1 AND irDetectRSide = 0 THEN
            DO
               irDetectRight = IN2
            LOOP UNTIL irDetectLSide = 0 OR irDetectRSide = 1
      ' ENDIF
        IF irDetectCenter = 0 THEN                      'START
            irDetectLeft = IN8
            FREQOUT 3, 1, 38500
            irDetectRight = IN2
          PAUSE 1000 'pause to show signal detected
            IF (irDetectLeft = 1 AND irDetectRight = 0) THEN                      ' evaluate duration
              GOSUB turnLeft
            ELSEIF (irDetectLeft = 0 AND irDetectRight = 1) THEN
              GOSUB turnRight
            ELSEIF (irDetectLeft = 1 AND irDetectRight = 1) THEN
              GOSUB turnDecide
            ELSE
              GOSUB turnReverse
            ENDIF
            ENDIF
            LOOP
                                            'END
    END
    turnLeft:
        DO
            PULSOUT Lmotor, LRev
            FREQOUT 8, 1, 38500
            irDetectLeft = IN9
            FREQOUT 5, 1, 38500
            irDetectCenter = IN4
            FREQOUT 2, 1, 38500
            irDetectRight = IN0
        LOOP UNTIL IN0 = 1
    RETURN
    turnRight:
        DO
            PULSOUT Rmotor, RRev
            FREQOUT 8, 1, 38500
            irDetectLeft = IN9
            FREQOUT 5, 1, 38500
            FREQOUT 2, 1, 38500
            irDetectRight = IN0
        LOOP UNTIL IN9 = 1
    RETURN
    turnReverse:
        FOR mLoop = 0 TO 50
            PAUSE 20
            PAUSE 20
        NEXT
        DO
            FREQOUT 8, 1, 38500
            irDetectLeft = IN9
            FREQOUT 5, 1, 38500
            FREQOUT 2, 1, 38500
            irDetectRight = IN0
        LOOP UNTIL IN9 = 1
    RETURN
    turnDecide: 'uses lower resistance to see further
        FREQOUT 9, 1, 38500
        IF (irDetectLSideFar = 1 AND irDetectRSideFar = 0) THEN                      ' evaluate duration
              GOSUB turnLeft
            ELSEIF (irDetectLSideFar = 0 AND irDetectRSideFar = 1) THEN
              GOSUB turnRight
            ELSEIF (irDetectLSideFar = 1 AND irDetectRSideFar = 1) THEN
              GOSUB turnLeft
            ELSE
              GOSUB turnReverse
        ENDIF
    RETURN
    ModEdit: code tags added
  • BTW what causes the cent to be a problem is when I take the apostrophe away from the endif statement in the middle of the Main code. As seen in the code above it has an apostrophe, i meant to take that out. This ENDIF statement is needed for the LOOP
    edited 2022-04-16 18:05
    If you can post yor complte code using the code tag...
    Three back ticks, (```)
    CR
    insert code
    CR
    Three back ticks,(```)
    CR
  • Here is my file on the basic stamp editor, im having problems copying the code with code tag.
  • BS2 file even better.
  • GenetixGenetix Posts: 1,764
    edited 2022-04-17 02:12
    Peter167,
    These are useful references.
    https://www.parallax.com/go/PBASICHelp/Content/LanguageTopics/Reference/ElementsStyle.htm
    https://www.parallax.com/package/basic-stamp-manual/
    Your code is cluttered and hard to read.
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    ' {$PORT COM3}
      mLoop VAR Word
        irDetectLeft = IN8
        irDetectRight = IN2
        irDetectRSide = IN0
      IF (irDetectLSide = 0 AND irDetectRSide = 0) THEN main
    Main:
      PAUSE 1000
      DO
          irDetectRSide = IN0
        IF (irDetectLSide = 0 AND irDetectRSide = 1) THEN
          DO
            IF (irDetectCenter = 0) THEN cent     ' <--- ???
              irDetectRight = IN2
          LOOP UNTIL (irDetectLSide = 1 OR irDetectRSide = 0)
        ELSEIF (irDetectLSide = 1 AND irDetectRSide = 0) THEN
          DO
              irDetectRight = IN2
          LOOP UNTIL (irDetectLSide = 0 OR irDetectRSide = 1)
        ' ENDIF     ' <--- Why?
            irDetectLeft = IN8
          FREQOUT 3, 1, 38500
            irDetectRight = IN2
            GOSUB turnLeft
            GOSUB turnRight
            GOSUB turnDecide
          ELSE
            GOSUB turnReverse
          ENDIF
        ENDIF
      LOOP
                                            'END
      END
    turnLeft:
      DO
        FREQOUT 8, 1, 38500
          irDetectLeft = IN9
        FREQOUT 5, 1, 38500
        FREQOUT 2, 1, 38500
          irDetectRight = IN0
      LOOP UNTIL IN0 = 1
      RETURN
    turnRight:
      DO
        FREQOUT 8, 1, 38500
          irDetectLeft = IN9
        FREQOUT 5, 1, 38500
        FREQOUT 2, 1, 38500
          irDetectRight = IN0
      LOOP UNTIL IN9 = 1
      RETURN
    turnReverse:
      FOR mLoop = 0 TO 50
        PAUSE 20
        PAUSE 20
      NEXT
      DO
        FREQOUT 8, 1, 38500
          irDetectLeft = IN9
        FREQOUT 5, 1, 38500
        FREQOUT 2, 1, 38500
          irDetectRight = IN0
      LOOP UNTIL IN9 = 1
      RETURN
      FREQOUT 9, 1, 38500
        GOSUB turnLeft
        GOSUB turnRight
        GOSUB turnLeft
      ELSE
        GOSUB turnReverse
      ENDIF
      RETURN
    Chapter 7 of Robotics with the BOE-Bot is on Infrared Object Detection.
    A LOW or 0 means that an object IS detected, and a HIGH or 1 means that NO object was detected.
    Your mystery line means that when the Center IR detector sees something it should... we don't know.
    Is this all you were given?
  • @Genetix
    Yes, this was all that I was given to me. Im trying to get it so it can guide its way through a maze using the infrared detectors for a little show for incoming students.
  • for reference here is the circuit design,
  • Peter167,
    The program and the diagram have some differences.
    The diagram has P4 as the Front Right transmitter, and P2 as the Far Right Side transmitter.
    Front Right should be P4 and P3, but the program uses P3 and P2.
    Far Right side uses P2 but is P4 in the program.
    The 1st IF...THEN...ELSEIF looks for irDetectRSide, but uses the Front Right for detection.
    Which IR directions are TurnLeft, TurnRight, and TurnReverse supposed to use?
  • I once again have changed to project a bit to combine some of an old code that I had using specific distances with the addition of using two IR sensors on the left and right side to slow down the wheels when it comes to close to a wall to keep it from running into any sidewalls. I'm currently just trying to figure out how I can have the frequency scanning while the Boebot is traveling on its specific. As shown in the BS2 file I'm trying to make X = 1 to that it can run while looping so when X = 1 the frequency sweep is active so it would be running the entire time, although I'm trying this currently it's not working how I want it to.
  • I Think I figured out my previous problem but i am now stuck with it saying that my Data occupies the same location as my program..... any help here?
  • does this basically mean that I have too much for it to hold? I can try to shorten/combine some of the subroutines if so.
  • I guess I could buy the bs2p microcontroller but I want to ask if I'm correct before I spend $200 on it for next-day shipping
  • Peter167,
    The BS2 has only 2K of EEPROM and you repeat the same code segments over and over again.
    Notice how the wheel pulse rates are treated as variables in the IR roaming programs starting on page 250 of Robotics with the BOE-Bot.
    In AvoidTableEdge on page 245, the number of servo pulses is also a variable.
    Look at the code segment at the bottom of page 133 to see as a perfect example.
    The more often that you can use the same segment of code and the same variables, the more compact your program will be.
    I see that you are using some of the code from Chapter 8, Activity 1 but your starting frequency values don't match.
    What's a Microcontroller is a good reference for basic BS2 programming.
    https://www.parallax.com/package/whats-a-microcontroller-and-linked-downloads/
    StampWorks deals with more advanced BS2 programming.
    https://www.parallax.com/package/stampworks-experiment-kit-manual-and-code/
  • Very helpful, thank you!
