Cannot compile "put" — Parallax Forums
mount "/sd", _vfs_open_sdcard()
dim r,test as ulong
chdir("/sd")       ' set working directory
open "/sd/testfile" for output as #3
put #3,0,test,1,r
close #3
The result:
/home/pik33/programowanie/P2-retromachine/Propeller/Tracker player/test112.bas:6: error: Unsupported operator 0x0
  • dgatelydgately Posts: 1,643
    edited 2022-03-07 11:34
    Could be that the pos parameter needs to be a '1' or greater...
    The flexprop BASIC language description of put includes "starting at position pos in the file (where pos is 1-based)"
    put #handle, pos, var [,items [,r]]
    put is used to write binary data to the open file whose handle is
    handle, starting at position pos in the file (where pos is 1-based).
    The position is optional, but if omitted a comma must still be
    placed to indicate that it is missing. var is the variable containing
    the first binary data to write, and items is the number of variables
    to write starting at var. items is often omitted, in which case only 1
    item is written. Note that the total number of bytes written is items
    times the size of each variable.
    Try:
    put #3,1,test,1,r
    OR
    put #3,1,test,r    <== if there's only 1 item, no need to state that
    Just a guess, really!
  • pik33pik33 Posts: 2,417
    edited 2022-02-22 16:53
    I tried
    put #3,1,test,1,r
    and
    put #3,,test,1,r
    with the same result
  • @pik33 said:
    and
    put #3,,test,1,r
    Did you try?:
    put #3,1,test,r    <== check your commas
    @dgately said:
    @pik33 said:
    and
    put #3,,test,1,r
    Did you try?:
    Now I did.
    error: Cannot take address of expression
  • This compiled for me with flexprop version 5.9.8...
    dim r,test as ulong
    'put #3,0,test,1,r   <== commented out
    put #3,1,test,r      ' added
    close #3
    "/Users/myUser/flexprop/bin/flexspin" -2 -l --tabs=2 -D_BAUD=230400 -O1    --charset=utf8 -I "/Users/myUser/flexprop/include" -I "/Users/myUser/flexprop/include/spin" -I "/Users/myUser/Documents/P2ESCode/p2library"  "/Users/myUser/Documents/P2ESCode/putTest.bas"
    Propeller Spin/PASM Compiler 'FlexSpin' (c) 2011-2022 Total Spectrum Software Inc.
    Version 5.9.8 Compiled on: Jan 31 2022
    putTest.bas
    mount.c
    fmt.c
    vfs.c
    errno.c
    posixio.c
    fatfs_vfs.c
    |-ff.cc
    bufio.c
    stat.c
    strncpy.c
    strncat.c
    strncmp.c
    ioctl.c
    strcpy.c
    memset.c
    sdmm.cc
    stat.c
    malloc.c
    strcpy.c
    memset.c
    putTest.p2asm
    Done.
    Program size is 46760 bytes
    Finished at Wed Feb 23 06:06:12 2022
    What flexprop version are you running?
  • There's a bug in the setting of the put/get result value. Either leave the result off, or else use the current github source code which has this fixed.
    Thanks for the bug report,
    edited 2022-02-26 10:26
    I compiled the newest version - Prop2Play stopped to do the directory/file list. I had to return to older Flexprop, which can compile working prop2play. If I manage to catch the error using the simple example, I will put it here.
    Edit: the bug can actually be in prop2play, but the older Flexprop can make it work as expected while the new Flexprop cannot - I am now testing simple examples to catch the problem.
    edited 2022-02-26 15:15
    I got lost. Simple examples work, the player does not. What is weird, is - in the player:
      close #5                                      ' todo: react to other errors (message box?)
      open currentdir$+"dirlist.txt" for output as #5
      print #5,".."+space$(36)                              ' this file system has no .. - it needs to be manually added
      filename$ = dir$("*", fbDirectory)                            ' find all directories
      while filename$ <> "" andalso filename$ <> nil
        if len(filename$)<38 then filename$=filename$+space$(38-len(filename$))     ' the string has to be exactly 38 characters
        filename2$=right$(filename$,38)                         ' which enables to use get when reading
        print #5, filename2$
     '   print filename2$                             ' write directory name to the file)
        filename$ = dir$()
      end while
      close #5
    I commented out opening #0 in the player, so I used standard system print to serial terminal for testing this
    If I uncomment the line "print filename2$" the loop works and the directory list is saved to a file and printed on ANSI termina;
    If I comment the "print filename2$" line as in this code block, it lists only first directory element to the file.
    The next step: compile with old and new flexprop, compare the lst files.
    Edit: lists are different:
    new:
    01ad0     C6 00 00 FF
    01ad4     22 6E 06 F6 |     mov arg01, ##@LR__1567
    01ad8     10 70 06 F6 |     mov arg02, #16
    01adc     6C DC B0 FD |     call    #__system___basic_dir
    01ae0     14 81 02 F6 |     mov local03, result1
    01ae4     04 00 00 FF
    01ae8     68 FB 05 F1 |     add objptr, ##2408
    01aec     FD 80 62 FC |     wrlong  local03, objptr
    01af0     04 00 00 FF
    01af4     68 FB 85 F1 |     sub objptr, ##2408
    01af8                 | '   filename$ = dir$("*", &h10)                         ' find all directories
    01af8                 | '   while filename$ <> "" andalso filename$ <> nil
    01af8                 | LR__0048
    01af8     04 00 00 FF
    old:
    01ad0     C6 00 00 FF
    01ad4     80 6E 06 F6 |     mov arg01, ##@LR__1565
    01adc                 | '     return _basic_dir(pat, attrib)
    01adc     D0 5F B0 FD |     call    #__basic_dir
    01ae4     04 00 00 FF
    01af0     04 00 00 FF
    01af8                 | LR__0048
    Instead of __basic_dir we have now __system__basic_dir... to be continued...
    I gave up. :(
    My "old" flexprop that compiles running version of prop2play is Version 5.9.9-beta-HEAD-v5.9.7-19-g1c955d38 Compiled on: Feb 12 2022
    My "new" flexprop that compiles not fully working prop2play is Version 5.9.9-HEAD-v5.9.7-33-g89e95693 Compiled on: Feb 26 2022
    I don't know what changed and what can make such difference. The workaround is to continue with the "old" version
  • Does changing the optimization level change the behavior?
  • Wuerfel_21Wuerfel_21 Posts: 5,790
    edited 2022-02-26 15:58
    @pik33 said:
    I gave up. :(
    Given you seem to be compiling the compiler yourself, try the git bisect command on the spin2cpp repository. That lets you find the change that causes your issue. Basically, you'd do
    git bisect start
    git bisect bad HEAD
    git bisect good 1c955d38
    and then it checks out some in-between version for you. Compile that with
    make clean
    make
    and test with the built compiler. If it works, git bisect good, else git bisect bad. It will then check out another version, etc, repeat until it has found the commit of interest. Then git bisect reset to return the repository to a clean state.
    edited 2022-02-26 16:44
    I will try to do this git thing (which I didn't know of yet).
    I compile with -O1. O2 gives garbage.:
    error: Internal error exceeded local register limit, possibly due to -O2 optimization needing additional registers or code being too complicated
    Without optimization the code is way too huge (256 K or something like this). It is already way too huge with -O1 but I will consider a size optimization when all basic things can work. Now it is still at alpha stage.
    The result:
    pik33@pc:~/Programowanie/src/flexprop/spin2cpp$ git bisect good
    495461ad639b5260c503622c66dc3d6b040109b7 is the first bad commit
    commit 495461ad639b5260c503622c66dc3d6b040109b7
    Author: Eric Smith <ersmith@totalspectrum.ca>
    Date:   Sat Feb 12 09:11:29 2022 -0400
        move BASIC declare lib functions into the system module
     Changelog.txt           | 3 ++-
     doc/basic.md            | 2 ++
     frontends/basic/basic.y | 4 ++--
     3 files changed, 6 insertions(+), 3 deletions(-)
    So, yes, that was the change which made the difference.
    What I did, was:
    • delete all Flexprop related files and directories
    • git clone the newest Flexprop
    • edit frontends/basic/basic.y reverting the changes in lines 1941 and 1981 from
    DeclareFunction(systemModule, rettype, 1, funcdef, body, attrib, $1);
    back to
    DeclareFunction(current, rettype, 1, funcdef, body, attrib, $1);
    Then after make install.. it works
    The question is: why this change made this difference
  • I've made some changes just now that might help your situation. The root problem is that some functions are being duplicated in the system and main modules.
    It works, but dir$("*", fbNormal) still lists also directories, which I think it shouldn't do as there is no way to get a list of files only. This is now not a problem, I know where to add the patch.
            if (oldattrib != 0) {
                r = stat(ent->d_name, &sbuf);
                if (r) {
                    // error in stat, break
                    return "";
                mode = sbuf.st_mode & S_IFMT;
                attrib = 0;
                if (ent->d_name[0] == '.') {
                    attrib |= fbHidden;
                if (0 == (sbuf.st_mode & (S_IWUSR|S_IWGRP|S_IWOTH))) {
                    attrib |= fbReadOnly;
                } else if (mode != S_IFDIR) {
                    attrib |= fbArchive;
                if ( mode == S_IFDIR ) {
                    attrib = fbDirectory;
                } else if ( mode == S_IFCHR || mode == S_IFBLK || mode == S_IFIFO) {
                    attrib = fbSystem;
                if ( 0 == (attrib & oldattrib) ) {
                    continue;
