Problem with PLX-DAQ tools
Hello everyone,
Since I changed my computer, the PLX-DAQ tool does not work because I switched to 64 bits whereas 32 bits are needed.
Has anyone come across this problem before ?
If so, has he found a solution?
thanks in advance
Paul
Don't know if this will help:
https://www.parallax.com/plx-daq-updated-for-excel-windows-10-and-propeller-2-early-adopter-progress/
https://forum.arduino.cc/t/plx-daq-version-2-now-with-64-bit-support-and-further-new-features/420628/401?page=21
Thank you for these links, I tried but it does not change anything to my problem.
Thanks anyway
Why PLX-Daq cant connect wit USB serial virtual port. Is there is any way around?
Yves
What is you hardware setup, (MPU) and Computer system?
I'm Using windows 10 with Intel(R) Celeron(R) N4100 CPU @ 1.10GHz 1.10 GHz 64 bit
Please note that PLX-DAQ works with real serial data but not PLX-DAQ. or any other serial app like other terminals. The only terminal that capture my Virtual port is Tera Term vers. 4.105
