Prop tool 2.6.2
pilot0315
in Propeller 2
I had this problem a few years back. Can't remember how to fix. for some reason the path to the library or work folders is not working. What am I missing. Sorry guys I have been out of the loop for over a year and am re setting up everything.
With the new Propeller Tool you have to save before compiling. Mind the extension.
Thanks Jon
BTW, jm_fullduplexserial has a method called tstart() for terminal output -- you only have to specify the baud rate you want to use.
